Author Topic: AWEKAS uploading has stopped  (Read 705 times)
Offline xmas111
    • http://www.johnsweather.com
« on: April 24, 2024, 04:30:30 PM »
I was checking my AWEKAS webpage and noticed it hasn't received had any new weather data from WifiLogger V2 since Jan. 2024.
The user name and password in WfiLogger are correct. I used them to log into AWEKAS and they work.
Anyone else having issues uploading to AWEKAS?
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: AWEKAS uploading has stopped
« Reply #1 on: April 25, 2024, 03:58:16 AM »
Fine on my end.
Offline Jiveborn
  • Jan
    • Jiveborn
« Reply #2 on: April 25, 2024, 06:35:32 AM »
Hi! Have You tried to check the AWEKAS account? Under the "Weather station" settings, you can see which data Aweka receives from your station. It is in any case a possible solution.
Best regards Jan
Offline xmas111
« Reply #3 on: April 25, 2024, 08:44:48 AM »
Jan,
    Yes I've checked my station settings.  In the picture below you can see I've checked the ones I want to use.
    Thanks for the suggestion.
« Reply #4 on: April 25, 2024, 09:18:10 AM »
Is there any information in the /debug logging?
Offline xmas111
« Reply #5 on: April 25, 2024, 10:40:57 AM »
Paul,
   Thanks for the information.
   It's very odd, I started the debug/logging and it shows the functions it's performing then just as it starts to show the uploads the screen go black and stays black.
   Is that normal?
« Reply #6 on: April 25, 2024, 11:42:51 AM »
It is difficult to follow with the ongoing processes but for me entering wifiloggerIPaddress/debug in a browser it displays all the uploading processes, including AWEKAS
AWEKAS 5
 1 195.189.4.150
 Client response time: 300 AWEKAS status: 1
Are you also running any other program that can upload to AWEKAS such as CumulusMX?
Offline xmas111
« Reply #7 on: April 25, 2024, 01:27:49 PM »
Yes, I'm also uploading to WeatherLink, PWS, and a few others.
When watching the debug it shows uploading to those sites but as soon as it starts to upload to AWEKAS the screen goes black.
I'll try and make a video showing exactly what happens.
Offline xmas111
« Reply #8 on: April 26, 2024, 02:50:29 PM »
I made a video of the debug/logger.
Here's a link to it.  You can jump to 3:30 miniutes, that's where it starts to upload to various websites.
Just after it starts uploading to AWEKAS the web browser window goes black.
https://www.youtube.com/watch?v=rDexsAIHT9Y
« Reply #9 on: April 26, 2024, 04:48:20 PM »
This may be one for Wojtek...
What firmware are you on?
I am on Wifilogger v2 2.42 and my debug displays much more as you can see in the attached zip but I do more uploads and also have CumulusMX run from the WiFiLogger on an ongoing basis except for 20 sec disconnect.  I do notice in mine that after the CWOP and AWEKAS is triggered each time it has some extra text including a huge 302 like in the screen capture.
Your Youtube shows your CWOP with error so is it related?!?
Offline xmas111
« Reply #10 on: April 26, 2024, 05:05:30 PM »
Paul,
   I'm on version 2.43. Was on 2.42 and thought maybe upgrading to 2 .43 would fix the issue but not such luck.
   I noticed the error with CWOP but CWOP is getting the data.
   Also did a factory reset on the WifiLogger and re-entered all the export information for each site with no luck.
   I think you're right, I should probably contact Wojtek and see if he can figure it out.
   Thanks for all your help.
Offline xmas111
« Reply #11 on: May 01, 2024, 06:20:21 AM »
Well, I've given up on Wifilogger to upload to AWEKAS.
I'm using Weatherlink Live to do it and it's working just fine.
