Is this still in testing? I've spent the entire day trying to get my WS-2000 data available to CumulusMX with both the Fine Offset Solar (CMX couldn't find the signal) and HTTP Upload (Ambient) (I must have something configured incorrectly, see below) station options. I'm using the local version of the site @ C:\CumulusMX\LocalSite\.
Config in WS View:
- Ambient Protocol
- Server IP: 192.168.1.118
- Path: Unchanged
the PATH must be /station/ambient? - the trailing "?" is important !!!
- Port: 8998
- Interval: 20
- Router info was given.
None of the CMX admin site views show data. The site throws this error when navigating to the Dayfile log.
DataTables warning: table id=dayfile - Invalid JSON response. For more information about this error, please see http://datatables.net/tn/1
When launching CMX.exe:
Cumulus MX v.3.13.3 build 3148
Working Dir: C:\CumulusMX\
Cumulus running at: http://localhost:8998/
http://192.168.1.118:8998/
Open the admin interface by entering one of the above URLs into a web browser.
Today.ini = data\today.ini
Last update=2021-09-23T15:34:13
Normal running
9/23/2021 3:34:13 PM
Type Ctrl-C to terminate
My Ambient console and WIFI firmware have been updated to the latest versions.
Lots of other threads on here about this topic, so apologies if I haven't found the right one yet.
First of all I'm not sure how to translate your wording .... ("I'm using the local version of the site @ C:\CumulusMX\LocalSite\")
but anyway
with the above WSView settings - see my comments in blue/red and having chosen at
http://localhost:8998 under settings / station settings/ general settings in CMX "HTTP (Ambient )"
- don't forget to save the settings !
and after a restart of CMX you should see your WS-2000 values on the CMX (administration) dashboard
(it might be helpful to choose a logging interval of 1 minute at settings / station settings/ general settings )
It should look like below: (you might have a decimal point instead of a comma and imperial units
If it doesn't work, switch on the logging in Program Settings / Logging options/ Debug options (unless already tagged),
and provide the log from your last restart from the ..../CumulusMX/MXdiags folder (should be the file with the newest time stamp as file name) - attach the txt file
(just copy the file, CMX can continue running)
(by the way, regarding a later post of yours, the directory /station/ambient doesn't need to exist on your local disk, it's for the CMX inbuilt webserver to handle the http post from the console)
if you see your station values in the admin interface (dashboard) but have trouble with showing the administration interface values on a web site of your choice (remote, local, ...),
that's a different situation; let me know
