Weather Station Hardware > What Weather Station Should I Buy?
Open source anemometer with replaceable bearing
davidmc36:
Reed switches sure can be non-durable. But cheap and usually easy to replace. Be nice to see under hood of Peet.
https://blog.towerup.com/wind-speed-measurements-with-anemometer-and-a-raspberry-pi/
That has other attachments since it has temp and humidity also.
doubleohwhatever:
--- Quote from: johnd on May 14, 2021, 05:40:25 AM ---Not in the sense you mean. The 6332 box does indeed convert the anemometer output into a digital format but then transmits it over proprietary wireless.
--- End quote ---
Proprietary but known and documented:
https://github.com/kobuki/VPTools
johnd:
--- Quote from: doubleohwhatever on May 15, 2021, 10:38:41 PM ---
--- End quote ---
--- End quote ---
Certainly, and has been for quite a few years. It's an excellent project, but for this particular project I'm not sure that the extra cost and complication is worth it compared to connecting the anemometer direct to a Pi with an A/D HAT. And I still suspect that a $4 Pi Pico would do all that the OP wants and also has A/D built in. But sure, it's certainly another option.
[*] Previous page
