In ajaxWDwx3.js you have differing time display between Metric and Imperial.
// UNITS-OF-MEASURE / UOM (optional)
// ... change to your desired UOM's and decimal places
// ENGLISH (Imperial)
var imperialUOM =
{Temp: '°F' // [ &dec;C | &dec;F ] ......................... Temp
,Wind: 'mph' // [ kts | mph | kph | m/s ] ................. Wind
,Baro: 'inHg' // [ hPa | mb | inHg | mmHg ] ................. Baro
,Rain: 'in' // [ mm | in ] ............................... Rain
,Soil: 'in' // [ cm | in ] ............................... Soil Sensor Depth
,Moist:'cb' // [ kp | cb ] ............................... Soil Moisture
,Snow: 'in' // [ cm | in ] ............................... Snow
,Alti: 'ft' // [ m | ft ] ........................... Altitude
,Dist: 'miles' // [ m | km | miles] .................... Distance
,Deg : '°' // [ deg | ° ] ..................... Direction/UV
,dateFmt: "m/j/Y" // 04/26/2009 ... same format as "date" function in php ( eg. for US use "m/j/Y", for GB use "d/M/Y" )
,timeFmt: "g:i:s a" // 3:27:01 pm ... same format as "date" function in php ( for 24h clock use "H:i:s" )
,timeHM : "g:i a" // 3:27 pm ...... same format as "date" function in php ( for 24h clock use "H:i" )
var imperialDP = // decimal places
{ Temp:1 ,Wind:1 ,Baro:2 ,Rain:2 ,Soil:0 ,Moist:0 ,Snow:2 ,Alti:0 ,Dist:2 ,UV:0 };
// METRIC
var metricUOM =
{Temp: '°C' // [ &dec;C | &dec;F ] ..........................Temp
,Wind: 'kph' // [ kts | mph | kph | m/s ] ................. Wind
,Baro: 'hPa' // [ hPa | mb | inHg | mmHg ] ................. Baro
,Rain: 'mm' // [ mm | in ] ............................... Rain
,Soil: 'cm' // [ cm | in } ............................... Soil Sensor Depth
,Moist:'kp' // [ kp | cb ] ............................... Soil Moisture
,Snow: 'cm' // [ cm | in ] ............................... Snow
,Alti: 'm' // [ m | ft ] ........................... Altitude
,Dist: 'km' // [ m | km | miles] .................... Distance
,Deg : '°' // [ deg | ° ] ........................ Direction
,dateFmt: "j-M-Y" // 26-04-2009 ... same format as "date" function in php (eg. for DE use "j.M.Y", for NL use "j-M-Y)
,timeFmt: "H:i:s" // 15:27:01 ..... same format as "date" function in php ( for 12h clock use "g:i:s a" )
,timeHM : "H:i" // 15:27 ........ same format as "date" function in php ( for 12h clock use "g:i a" )
var metricDP = // decimal places
{ Temp:1 ,Wind:1 ,Baro:0 ,Rain:1 ,Soil:0 ,Moist:0 ,Snow:2 ,Alti:0 ,Dist:2 ,UV:0 };
