Author Topic: Need help setting up my webcam on weather underground  (Read 10016 times)
Offline Michael M
    • mypensacolaweather.com
Re: Need help setting up my webcam on weather underground
« Reply #50 on: November 17, 2019, 09:24:38 PM »
well that's a problem
you do not need to port forward the camera
remove the port forwarding from the router
that would make a network loop on itself
WU
KFLPENSA29  WU is currently Online Again
Got New Station Installed 9-2-22
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #51 on: November 17, 2019, 09:29:18 PM »
I do port forwarding on my cameras so that I can access them remotely.  The http port is the only one that was changed.
Offline Michael M
« Reply #52 on: November 17, 2019, 09:30:48 PM »
should not be port 21
make it 80 or 8000 or anything but 21
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #53 on: November 17, 2019, 09:31:48 PM »
The http port is 50211
Offline Michael M
« Reply #54 on: November 17, 2019, 09:33:05 PM »
ok that's fine
do you know what type of file the image from the camera is?
.jpg
.avi
.mpg?
« Last Edit: November 17, 2019, 09:35:00 PM by daddy2425 »
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #55 on: November 17, 2019, 09:38:22 PM »
But do I need to configure my router for port 21?
Offline Michael M
« Reply #56 on: November 17, 2019, 09:38:33 PM »
Well we know its not the WU server having the issue
it configuration on the camera
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #57 on: November 17, 2019, 09:39:20 PM »
Just setup port forwarding, and now I get Access Denied.
Offline Michael M
« Reply #58 on: November 17, 2019, 09:41:23 PM »
Access denied from what
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #59 on: November 17, 2019, 09:43:00 PM »
That's just the message I get.
Offline Michael M
« Reply #60 on: November 17, 2019, 09:44:17 PM »
From the WU server?
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #61 on: November 17, 2019, 09:44:28 PM »
If I insert a "/" in the directory field, I get "500 Internal Server Error  Failed FTP Upload 553"
Offline egnlsn
« Reply #62 on: November 17, 2019, 09:44:50 PM »
That's my suspicion.
Offline egnlsn
« Reply #63 on: November 17, 2019, 09:45:37 PM »
Same thing if I use webcam.wunderground.com as the Host.
Offline Michael M
« Reply #64 on: November 17, 2019, 09:49:02 PM »
I really need to login I to your PC and see the setting you got if we are going to fix this
TeamViewer is software where you and me are on the pc together and at  the same time
you can disconnect me at anytime you wish
its a one time connection not all the time
that's why there is a ID and password it changes every time it is used
« Last Edit: November 17, 2019, 09:52:06 PM by daddy2425 »
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #65 on: November 17, 2019, 09:53:49 PM »
Now, I'm getting "500 Internal Server Error  Failed FTP Upload 553" all the time.
I'm sorry -- I just can't do that.  I really do appreciate your wanting and trying to help me with this, but it's just not important enough for me to allow access to my computer to someone I don't even know.
Offline Michael M
« Reply #66 on: November 17, 2019, 09:58:13 PM »
I understand
well we know it is not the WU server
I was uploading my camera to it
so just keep playing around with it you may find the right configuration and all goes to working
good luck
sorry I couldn't get you hooked up with your camera online
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #67 on: November 17, 2019, 09:59:44 PM »
Again, Michael, I really do appreciate all of your efforts.  Have a GREAT evening!
Offline Michael M
« Reply #68 on: November 17, 2019, 10:03:49 PM »
You too
if you get working
Let me know
Thx
WU
CWOP DW7066
[AKA]  Michael
« Reply #69 on: November 17, 2019, 10:47:45 PM »
I believe that the FTP menu being used (from screenshot earlier) for this Axis camera is for FTPing video not picture stills.
The process to FTP stills is a bit more complex with this camera:
https://www.axis.com/en-rs/support/faq/FAQ115997
Also please send out Webcam keys via PM and not on the open forum.
Offline Michael M
« Reply #70 on: November 17, 2019, 11:25:39 PM »
ok
well do
sorry
WU
CWOP DW7066
[AKA]  Michael
Offline egnlsn
« Reply #71 on: January 05, 2020, 11:37:56 PM »
galfert,
While the camera that FAQ was from is not the same model as mine, it did point me in the right direction.  The issue has been resolved, and my webcam is online.
Thanks to you and Michael for your help.
CIAO!
Ed N.
« Reply #72 on: January 06, 2020, 06:39:40 AM »
 [tup]
