Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48811 times)
Offline wsNoordbergum
    • wsNoordbergum
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #600 on: June 25, 2022, 03:28:07 PM »
I've now got three rain gauges for comparison to a manual rain gauge.
Today's rain:
Davis 9.4mm
WS90 7.9mm gain all set to 0.65
WH40 7.7mm
Manual 7.2mm
Seems Davis single spoon is counting to much rain....
If it is a persistent difference I'd better self calibrate the Davis rain gauge.
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
Online Gyvate
« Reply #601 on: June 25, 2022, 04:06:32 PM »
a note for the new 2.1.5fw. https://www.wxforum.net/index.php?topic=44041.msg448220#msg448220
a WH32(-EP) is not affected by the temperature compensation option - it's only applied to T/H sensors of the outdoor arrays (WH65/WS69, WS80, WS90).
Offline giusCB
  • www.turismometeo.it
« Reply #602 on: June 26, 2022, 06:16:43 AM »
good
www.turismometeo.it
Offline giusCB
« Reply #603 on: June 26, 2022, 06:17:31 AM »
Today's rain:
Davis 9.4mm
WH40 7.7mm
Manual 7.2mm
[tup] [tup]
www.turismometeo.it
Offline tweatherman
« Reply #604 on: June 30, 2022, 09:41:13 AM »
Today's rain:
Davis 9.4mm
WH40 7.7mm
Manual 7.2mm
What firmware are you running with those gains?
tweatherman
    • wsNoordbergum
« Reply #605 on: June 30, 2022, 09:53:28 AM »
WS90 119
Gw2000 2.1.5
Meteobridge nano SD
Offline tweatherman
« Reply #606 on: June 30, 2022, 10:21:36 AM »
WS90 119
Gw2000 2.1.5
Beta or Kickstarter unit?
tweatherman
Offline gosling1
« Reply #607 on: June 30, 2022, 10:35:31 AM »
Wittboy has been available on Amazon website (US) for a few weeks now... Reviews have been somewhat "mixed".
    • wsNoordbergum
« Reply #608 on: June 30, 2022, 10:38:24 AM »
WS90 119
Gw2000 2.1.5
tweatherman
Kickstarter project
Also compared to my WH40 the WS90 now records slight less rain than the WH40 with 0.65 gain set
Meteobridge nano SD
Offline Autofill
« Reply #609 on: June 30, 2022, 10:44:46 AM »
I'm happy with my Wittboy. Its a bit tinkerey, and might not be for someone who just bought and mounts it and forgets about it. If you're into doing stuff yourself (which most of us are here on this forum), you'll also be happy with it.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Online Gyvate
« Reply #610 on: June 30, 2022, 01:55:24 PM »
if it were that simple ...  :shock: - just had rather strong rainfall for about 30 minutes
WH65: 9.4 mm
WH40: 7.9 mm
WS90: 8.3 mm
gain = 1.0 for all gauges and tiers
the WH40 as usual will have lost some - due to the low rim
that was my last hardware revision and FW 1.1.19 WS90
my ß-WS90 reported 7.0 mm (also on 1.1.19)
0.65 as gain for all 5 tiers (as proposed earlier) would have been heavily underreading
Offline Arkadiusz_w
« Reply #611 on: July 07, 2022, 03:46:01 AM »
In my case, the gate GW2000 turned out to be faulty. Replacing with the old GW1100 solved the problem and the WS90 has been working properly for days. The latest GW2000 gate tended to freeze periodically for a few minutes and sometimes even hours.
WS90 - 19.4 mm
WS40 - 26.5 mm
During the recent heavy rainfall, it has emerged that the rainfall of the WS90 is greatly underestimated with a long, continuous rainfall. Soft 1.2.0. It was even about 6 liters.
Gain for WS90, 0,55, firmware 1.2.0
Gain for WS40, 1.022
Ecowitt WS90 1.3.8, WS80 1.2.5, Ecowitt WS68, Ecowitt WH31EP/WH32EP, WH40, WH57, WN34L, WH51, WN34D, HP2560_C, HP2550_C, GW1100, GW2000. Davis Vantage Pro 2, Davis Vue, Davis 6313, Hongyuv WDS2E
Barani Meteoshield Pro II, III, Davis FARS 24H
Online Gyvate
« Reply #612 on: July 07, 2022, 03:28:35 PM »
My GW2000 also was quite moody from the start ...
I think I have figured out that it (also ?) happens, when you connect to it via both interfaces WLAN and LAN, e.g. weewx or CMX querying via WLAN and WS View Plus and the WebUI via the LAN interface.
Over a longer period it also reported almost every day, over two minutes, an extreme drop in pressure readings by about 300 hPa.
However, since FW 2.1.5 has been installed,  it has become more stable, no more pressure drop-outs and freezers.
I have a 2nd GW2001 since a couple of weeks (also with a latest hardware revision WS90 on FW 1.1.19) and this station behaves without issues - both the GW2000 and the WS90. I have the WS90 gains all set on 1.0 and have it report together with my WH40 and my WS69 rain gauge into weewx. The WS90 readings (on a daily accumulation basis) oscillate between the WS69 and the WH40.
Beware of the difference in the vertical scaling between WS69/WH40 and WS90
« Last Edit: July 07, 2022, 03:42:58 PM by Gyvate »
Offline Autofill
« Reply #613 on: July 08, 2022, 09:46:12 PM »
I just started to experience this "freezing" or flatlinig of data with my GW2000. During the same time, the HP2551 was reporting correctly for the WS90. Not clear if its an internet/connection issue though, so I'll give it another chance before I bring it up with Ecowitt.
WS90 - 19.4 mm
WS40 - 26.5 mm
« Last Edit: July 08, 2022, 09:47:52 PM by Autofill »
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Mapantz
    • Wareham Weather
« Reply #614 on: July 08, 2022, 09:48:11 PM »
I just started experience this "freezing" also with my GW2000. During the same time, the HP2551 was reporting correctly for the WS90. Not clear if its an internet/connection issue though, so I'll give it another chance before I bring it up with Ecowitt.
Did you update to the latest firmware recently? Mine went pear shaped right after the update and it got worse. I sent it back in the end.
Offline Autofill
« Reply #615 on: July 08, 2022, 09:54:33 PM »
I have it on auto update, what FW is latest? Currently mine is 2.1.5, I don't know when it updated if it did.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline thunder.ky
  • Weathering all the things!
  • GW2000B, WS90, WeeWX, FOSHKplugin
    • thunder.ky
« Reply #616 on: July 08, 2022, 10:15:33 PM »
You're on the latest which is v2.1.5.
Ecowitt GW2000B v3.0.5 (Previous v2.2.4.8 )
Ecowitt WS90 v1.3.3
WeeWX v4.9.1
FOSHKplugin v0.10
https://wx.thunder.ky
Offline davidefa
« Reply #617 on: July 09, 2022, 04:14:55 AM »
What do you mean by saying "freezing or flatlinig"? Does it stop transmitting or does it transmits the same data repeatedly ( for all of the values from the sensor ) ?
In the second case it may indicate a problem in rf signal reception.
Every gateway should have a 'grace time' in which continues to transmit ( to the cloud, api... ) the last received value from the sensor before giving up ( this should mask occasional and short rf data loss )
« Last Edit: July 09, 2022, 04:17:29 AM by davidefa »
Offline Arkadiusz_w
« Reply #618 on: July 09, 2022, 04:31:21 AM »
In my case, the GW2000 was losing communication with the WS90. After a minute or a few minutes, he was recovering his communications, but sometimes the data interruptions lasted several hours.
The improvement in data transfer stability has not been made after updating the GW2000 to software version 2.1.5.
I already have a GW1100 on for a week and no technical problems in communicating with WS90 Wittboy.
Online Gyvate
« Reply #619 on: July 09, 2022, 05:49:01 AM »
if it behaves "moodily" as you describe, ask Ecowitt for a replacement.
My first GW2000 was reporting wrong (650 hPa Abs) pressure readings for 2-3 minutes once almost every day (at different times though).
I got it replaced and the new one works flawlessly for 3 weeks now.
Offline Autofill
« Reply #620 on: July 09, 2022, 11:54:53 AM »
It doesn't seem to be a rf brodcast from the WS90 itself and here's how I know:
I've exposted teh WS90 to only 2 gateways:
HP2551C
GW2000
In a period where the issues happens, it only reports data, say once or twice in 3 hours, and ecowitt.net just joins the dots (hence the flatline). This is the case for the GW2000. However, during the same time period as reported by the HP2551C, all the data was there as normal.
Funny thing is, when the GW2000 was in this weird state, my WSVeiw plus app coud not connect to the GW2000, i.e. it would load and be grey, then it would turn light blue and I would press it to ente the live data, it ill try to load, but then go back to the main screen. I had to connect to the GW2000 using a computer and browser, which it connected almost immediately, at which point a rebooted the device from the web interface.
The fact that I connected to the GW2000 via the web interface without any issues, could rule out connectiviy issues, and perhaps related issues to hardware/firmware. I actually did report this to Ecowitt already as it seems at least 2 people have reported similar issues.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Online Gyvate
« Reply #621 on: July 09, 2022, 02:44:37 PM »
3 ways to reboot the GW2000
1. power-cycle
2. press the central big button (with "ecowitt" printed on it) for 5 seconds
3. reboot from the WebUI
Online Gyvate
« Reply #622 on: July 09, 2022, 03:02:08 PM »
- through which interface were you connecting to the WebUI ?
- through which interface does your WSView (Plus) connect ?
connecting and querying the GW2000 through both (WLAN and LAN) interfaces simultaneously can make it freeze (probably make one or both of  the interfaces freeze)
this has in my observation improved with firmware 2.1.5
Offline Autofill
« Reply #623 on: July 09, 2022, 08:38:49 PM »
Chrome via Windows 10 (wired computer)
Android app via WiFi.
Well it may be true what you're saying the freezing and flatlining started way before I tried to connect to the device.
I'm not convinced that it's a hardware issue of the Gateway, could be a firmware issue perhaps a memory leak over time. Might be addressed by a simple update who knows time will tell
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Online Gyvate
« Reply #624 on: July 10, 2022, 01:21:05 AM »
I don't say it is necessarily hardware caused but surely one way or the other hardware (network interface) related.
From the observation something in the handling of API requests coming in parallel through both interfaces, some queueing issue, some running into an endless loop, some bottleneck congestion ....seems to be happening - and that could only be solved by software i.e. firmware.
Ever since I made all my requestors (weewx, meteobridge, WS View Plus ....) only use one and the same interface, here the eth0, the gateway is stable. I haven't checked which interface is used for the posting, ecowitt.net and custom server, but these two activities don't seem to interfere with each other even when using both interfaces. (e.g. posts via WLAN and API requests via LAN)
