There's only a goal to put the gw1000 outside, and surely I will do next weeks
as you know, regarding temperature and humidity accuracy, if you are using a high-quality solar radiation shield, or a professional solar radiation shield, like Barani and others, the rule about the sensor is
"more little dimension is better is"
when, especially in a high-quality solar radiation shield, the ability to have the best internal airflow can give the best performance, more little will be the sensor more accurate will be the performances
In fact, one of my future goals is to have a gw1000 outside, in an IP66 protection box, and the little t/rh sensor inside an Apogee ts-100
Mauro
