Author Topic: Ecowitt - New Zealand  (Read 1179 times)
Offline Rocketman
« on: April 07, 2025, 12:49:13 AM »
New mast with WS80 & WN90LP on top
Vector Instruments A101M anemometer & A101K wind direction
Ecowitt WH57 lightning sensor
Ecowitt WD40 rain gauge
Mast is made out of two parts ( top piece is 3 piece Aluminuim telescopic ) bottom is Aluminuim fence rail
Was going to add a hinge onto the section which hold the two sections together
I should be able to fold the top section down 90 degrees ( use for updating firmware for the Ecowitt weather station sensors )
This setup gives me best of both worlds ( analog and ultrasonics sensors )
« Last Edit: April 09, 2025, 05:44:17 AM by Rocketman »
HP2550,FW 2.0.4, WS80 FW1.2.9, WH57 , WH40 , WH51, GW1100 FW2.3.4 , WN90LP FW1.4.7 wirelessly to Hongyuv HY Display, INKBIRD iAMQ-128W V1.1, WH55 x 2 , WN34D,Vector Instruments A101M & A101K , CumulusMX 4.4.5 b4088, Weather Display 10.37S 152
Offline Rocketman
Re: Ecowitt - New Zealand
« Reply #1 on: May 01, 2025, 07:58:37 PM »
Thought I show what screens are connected to the WS80 and WN90LP
Working on getting the analog sensor connected to the original logging unit
