Author Topic: Software Constantly Freezing  (Read 537 times)
Offline JesseLikesWeather
  • Weather Lover, HTML weather scripts on my website.
    • Panhandle WX
« on: September 23, 2024, 04:04:23 PM »
I use the Weather Display software to upload weather data to my website, but it is constantly freezing every time I try to make modifications. I figured it might be something to do with the uploading process. Any ideas?
JesseLikesWeather
YouTube: @JesseWx_ (JesseLikesWeather)
Offline weatherdoc
    • Weather Doc's Weather
Re: Software Constantly Freezing
« Reply #1 on: September 24, 2024, 07:21:25 AM »
It's a known issue with WD, assuming you are saying it is temporarily freezing up when you are making modifications. Since WD is still running and processing data while you are making changes, during certain processes it appears to be freezing up, but it's not really freezing up, it's just not allowing you to edit while that process is running. After several seconds, sometimes a bit longer, it will allow you to continue what you are doing. It's annoying but that is how it functions.
Offline NorCal_Dan
    • Traveling RV Wx
« Reply #2 on: September 24, 2024, 08:32:38 AM »
It might be a good idea to shutdown WD while you make changes.
    • Panhandle WX
« Reply #3 on: September 24, 2024, 12:03:47 PM »
Thanks for your opinions, I don't know exactly what you mean by shutting down WD, the software itself, or the uploading process?
JesseLikesWeather
Offline zeppline
    • Las Vegas Weather Guy
« Reply #4 on: September 24, 2024, 12:19:21 PM »
Check your status page you have several errors. They can slow down your computer.
    • Panhandle WX
« Reply #5 on: September 24, 2024, 12:24:11 PM »
I just turned off the Main & Override Switch when uploading to make my modifications. Thanks guys.
JesseLikesWeather
