Author Topic: Barani MS Pro vs SmartCellino radiation shield comparison  (Read 105815 times)
Offline mauro63
Re: Barani MS Pro vs SmartCellino radiation shield comparison
« Reply #625 on: January 20, 2025, 03:43:28 AM »
Yesterday's report, updated with averages and hourly deviations
M.
Offline Kallo78
« Reply #626 on: January 20, 2025, 02:51:54 PM »
Yesterday at my place. Photocopy days, gray, with very few emotions and subtle deviations. Instead of putting complete reports I put this summary.
Offline Kallo78
« Reply #627 on: January 21, 2025, 12:17:16 AM »
Report of yesterday 20/01/2025
Offline mauro63
« Reply #628 on: January 21, 2025, 02:58:32 AM »
Yesterday's report
M.
Offline mauro63
« Reply #629 on: January 21, 2025, 10:27:55 AM »
Soon, hopefully during the week, a second SMArtCELLino will be added to the one already present  ;)
M.
Offline mauro63
« Reply #630 on: January 21, 2025, 03:53:43 PM »
To clarify and to respond, albeit remotely, to statements in other posts, this installation is of very poor quality
The SRS are excessively close together, the height from the ground and the exposure are correct, but their extreme proximity triggers high uncertainties that vary based on the direction of natural ventilation
The SRS that finds itself working upwind of the others will always have an advantage, and gradually those "behind" it will find themselves in a worse situation
This is an installation that can provide acceptable comparison data only in the long term in order to cover the majority of different possible situations, the daily data, or worse, the instantaneous ones are seriously affected by this.
Let's all take this into account in our evaluations, even though there are certainly installations that are decidedly better than mine ;)
M.
Offline Kallo78
« Reply #631 on: January 22, 2025, 01:50:44 AM »
My yesterday data
Offline mauro63
« Reply #632 on: January 22, 2025, 03:39:49 AM »
Yesterday's report
M.
Offline Dvalente75
« Reply #633 on: January 22, 2025, 12:45:20 PM »
My Yesterday report
Offline Kallo78
« Reply #634 on: January 23, 2025, 03:32:40 AM »
Data yesterday. Complex despite the grayness. At night irradiation and wind blows active in some places. Interesting day reaction after 13 to the wind reinforcement where in Rad14 and Siap with DS something happened. What I do not know.
 fog and humidity
« Last Edit: January 23, 2025, 03:45:50 AM by Kallo78 »
Offline mauro63
« Reply #635 on: January 24, 2025, 03:04:54 AM »
Yesterday's report with two excellent analysis points in terms of time constants
I must admit that it would be nice if other users who have the Siap screen would also contribute, not to daily updates but at least to post an opinion, a graph etc. every now and then and they are not only the usual 2/3
M.
Offline Kallo78
« Reply #636 on: January 24, 2025, 09:41:37 AM »
Report of yesterday
Offline Kallo78
« Reply #637 on: January 26, 2025, 02:10:19 AM »
Report yesterday with probable wet-bulb registration for Siap and Pro3 from 12 to 14
Offline Dvalente75
« Reply #638 on: January 30, 2025, 03:05:58 AM »
My report of 28/01/25
Offline Kallo78
« Reply #639 on: January 30, 2025, 03:20:44 AM »
Report of Yesterday
Offline mauro63
« Reply #640 on: January 30, 2025, 08:10:04 AM »
A new Siap is added to the existing one, same height and exposure although, as already said, it is a poor quality station due to the excessive proximity of the various systems
In the new Siap a wn-34D, which we have been testing for several days and with extremely interesting results
Graphs and reports will follow
M.
Offline Jasper3012
« Reply #641 on: February 02, 2025, 04:19:50 PM »
Decided to make this little table for the 2 times I've registered a "significant" error on the SC (0.3C or more vs the Davis). This isn't particularly useful as there's a number of variables at play here that are not quantified, but there you go. Considering these 2 events were in the morning, with a quickly rising temperature, the actual errors are likely slightly higher than the values suggest, as the Davis warms faster due to its shorter time constant and therefore you'd actually expect to see the Davis a little warmer, not cooler like what happened here. A comparison between the SC and the Barani would not have that variable as I estimate the time constants of both shields to be very similar.
Update: I've marked the row of 11:00 on 13/01 in yellow as I feel like it's slightly misleading, the max error of 0.8C likely did not occur when the wind was at 5 km/h but probably just before the wind increased. Keep in mind that the reported wind speed values are 10 min averages, I assume the 0.8C error occurred just after 10:50 (when the wind was still weak, like it was in the 10:40-10:50 interval) and the jump in wind speed occurred after that 0.8C error.
Update 2: the wind speeds are recorded at 5 m, these are even weaker at shield height (~70% of the speed at 5 m).
« Last Edit: February 02, 2025, 04:28:55 PM by Jasper3012 »
Offline Meteorology fan
« Reply #642 on: February 03, 2025, 12:13:46 AM »
Here it would be optimal to see a comparison of Apogee TS-100 vs Davis FARS24H vs Smart Cellino. Davis can also tend to overheat in the absence of wind. I've seen it in person.
Ecowitt WS90 1.3.8, WS80 1.2.5, Ecowitt WS68, Ecowitt WH31EP/WH32EP, WH40, WH57, WN34L, WH51, WN34D, HP2560_C, HP2550_C, GW1100, GW2000. Davis Vantage Pro 2, Davis Vue, Davis 6313, Hongyuv WDS2E
PT1000 4-wire - Termio 2 (3x)
Barani Meteoshield Pro II, III, Davis FARS 24H, Apogee TS100
Offline mauro63
« Reply #643 on: February 03, 2025, 03:03:59 AM »
Yesterday's report
M.
Offline Kallo78
« Reply #644 on: February 03, 2025, 03:26:59 AM »
My yesterday's data
Cloudy day with drizzle at times
Offline mauro63
« Reply #645 on: February 04, 2025, 03:12:41 AM »
I hereby inform you that, starting today, Siap+Micros will be able to directly manage requests from private individuals without the need to contact me in advance, the official list price will be automatically applied.
This obligation remains only for MeteoNetwork Members for whom a discount from the list price is provided.
M.
« Last Edit: February 04, 2025, 03:53:30 AM by mauro63 »
Offline Kallo78
« Reply #646 on: February 04, 2025, 03:49:55 AM »
Report of yesterday
Offline mauro63
« Reply #647 on: February 04, 2025, 03:53:18 AM »
Yesterday's report
M.
Offline mauro63
« Reply #648 on: February 05, 2025, 02:50:28 AM »
Yesterday's report
M.
« Reply #649 on: February 05, 2025, 04:28:13 AM »
Yesterday's comparison of Davis Fars24h vs Smart Cellino at my friend's. You can see that with the low solar angle, we have not eliminated the problem of overheating of passive shields.
« Last Edit: February 05, 2025, 04:33:05 AM by Meteorology fan »
