Author Topic: Cumulus v1.9.2 won't update Twitter!  (Read 2848 times)
Offline William Grimsley
    • Newton Poppleford Weather
« on: October 20, 2012, 04:49:32 AM »
Hi guys,
For some reason (I am using Cumulus v1.9.2) Cumulus won't update my twitter with observation info!
Why is this the case? I haven't done anything...It has just stopped. :/
Will
http://www.newton-poppleford-weather.co.uk
Davis Vantage Vue - Cumulus v1.9.4 (1084)
Weather Underground: IDEVONEX12
Met Office WOW: 717144
PWS Weather: ENG128597
Offline tobyspond
Re: Cumulus v1.9.2 won't update Twitter!
« Reply #1 on: October 20, 2012, 06:02:50 AM »
Will,
Twitter changed some code, so version 1.92 will not work with twitter.  You need to upgrade to version 1.9.3 version 1051, which I thought you did yesterday.  There is a discussion on the sandaysoft forum about this issue.  You should spend some time over there reading.
Kerry
« Reply #2 on: October 20, 2012, 10:36:41 AM »
Hi Kerry,
But, I said it gave an error. Or it didn't update to my site correctly.
Will
« Reply #3 on: October 20, 2012, 10:56:36 AM »
Hi Kerry,
GREAT NEWS! I have Cumulus v1.9.3 going now...let's see what twitter does...I'll edit in an hour to see if it has updated. :D
Many thanks :D
Will
Offline tobyspond
« Reply #4 on: October 20, 2012, 01:14:03 PM »
Hi Will,
Looks like your twitter feed is working.  A suggestion, though, a five minute update is too frequent for twitter.  I suggest a minimum of two hours.  I use three.  If an interesting weather event is happening, you can always tweet about it in addition to the automatic feed.
It looks like the index.htm has replaced index.php again on your site.
Kerry
« Reply #5 on: October 20, 2012, 01:20:22 PM »
Hi Kerry,
Yes, I was just testing to see if it worked. I will now put it back to 2 hours! :D
Ok.
Will
