Author Topic: Phantom Temp Sensor  (Read 3261 times)
Phantom Temp Sensor
« on: November 02, 2013, 09:14:03 PM »
OK - I am stumped.  I have two extra sensors, but only one has a battery.  Yet WL is showing two - with different temps!  What the???
Offline dalecoy
    • Lee's Summit, MO
Re: Phantom Temp Sensor
« Reply #1 on: November 02, 2013, 09:32:24 PM »
Neighbor?
Offline johnd
« Reply #2 on: November 03, 2013, 03:12:10 AM »
Solar panel on the door of the phantom one? Or not?
Cambridge UK
« Reply #3 on: November 03, 2013, 07:57:30 AM »
No neighbours for miles.  And there is s solar panel on the mystery one but it is inside a dark closet.  Oh yeah - the mystery temp is fixed at 38.9c.
Offline johnd
« Reply #4 on: November 03, 2013, 08:44:46 AM »
Last reading received hasn't reset to dashed-out? (Not sure that all transmitter types do so.)
Cambridge UK
Offline dalecoy
    • Lee's Summit, MO
« Reply #5 on: November 03, 2013, 09:47:10 AM »
OK, what are the statistical and reception diagnostics for that transmitter ID?
« Reply #6 on: November 04, 2013, 09:24:33 AM »
Never thought about that.  Hmm...  Could be I guess.  Weird though that it started about a dozen hours after the other temp unit went into service.  I should have hooked it up I guess to see if it reset.
« Reply #7 on: November 04, 2013, 09:25:24 AM »
Not at the console now so I can't check.  But generally the system has been close to 100% for the working temp tx.
Offline dalecoy
    • Lee's Summit, MO
« Reply #8 on: November 04, 2013, 10:06:48 AM »
Not significant.  Look at the diagnostic for the "phantom" transmitter ID.
It's the logical diagnostic.  If the reception from the "phantom" sensor is good, then look for a working transmitter on that channel or some other RF symptom.  If the reception from the "phantom" sensor is zero, then for some reason the display is stuck.
Offline dalecoy
    • Lee's Summit, MO
« Reply #9 on: November 06, 2013, 08:58:41 PM »
Have you had a chance to check yet?
« Reply #10 on: November 06, 2013, 10:49:20 PM »
I am away from it now and did not see a way to get individual reception without being at the console.  I guess it is just that way...
Offline dalecoy
    • Lee's Summit, MO
« Reply #11 on: November 07, 2013, 11:35:35 AM »
That's correct.  Please let us know what the diagnostics say, when you can access the console.
What software are you using that shows the temperature from the phantom sensor?
« Reply #12 on: November 07, 2013, 01:35:41 PM »
Weatherlink
Offline dalecoy
    • Lee's Summit, MO
« Reply #13 on: November 07, 2013, 01:58:51 PM »
Weatherlink
I see you said that in the first posting - so I shouldn't have needed to ask.
Have you actually seen that 38.9 reading on the console?  Or are you just reporting what WeatherLink says for your hot tub temperature?
Also, when you get a chance, take a look at the actual data values (Browse Window).
Version of WeatherLink?
« Reply #14 on: November 07, 2013, 08:16:11 PM »
Was initially based on WL.  But I just logged in remotely and browse shows 38.9  WL 5.8.3    BTW, it did NOT do this last year.
Offline dalecoy
    • Lee's Summit, MO
« Reply #15 on: November 07, 2013, 09:27:08 PM »
Getting more and more interesting.  The reception statistics should be interesting, when you can get them.
