Now, one secret to the logitechs... and this can sound confusing.... sorry, can't help it... you do need the newest Logitech drivers, not the "pc" supplied drivers.... which are available from the Logitech site... You'll download the "package", and install it. It most likely will include the Programs. Now, in order to set the camera, focus, brite, etc, you do need the Logitech program. Once set, close, and kill all Logitech processes. Make sense? in other words, with "Generic" drivers, you have no camera control, but you only run the Logitech programs as needed, then after adjustments, kill em. The driver will remain active for the cams. Many times, there's no problem having them in background, but at times there are... depends on machine, other software, etc... so just keep 'em killed. For example... On WC7Pro, if I call for a cam adjustment, it will open the Logitech program,... but the program won't necessarily adjust the cam I want... it only tends to work on the FIRST cam it detected, the other cams may or may not follow those settings! But you do want the latest Logi Drivers.
