Author Topic: PWS monitor for Android/iOS  (Read 22084 times)
Offline superduty
Re: PWS monitor for Android/iOS
« Reply #75 on: August 06, 2019, 03:29:37 AM »
I am running on Galaxy S10 and I have a problem with min/max on temps and dew.
For today I show min/max temps of 158.5 and 159.6
dew 125.2 and 127.2
Hopefully a fix is in the works.  Once that is fixed, I will go for the paid version.
Thank you
Offline buffy
  • My PWS: Garni Ventus 830
    • PWS Monitor
« Reply #76 on: August 06, 2019, 03:55:25 AM »
dew 125.2 and 127.2
Thank you
Yes, this is a problem with unexpected data unit values... Sorry for that. Please try send me PM of your PWS WU ID for testing. If there is problem in app with downloading unexpected units, you see "F!" in units place in temp chart. Is it there?
I'm trying make new data download function for elimination this error.
Offline buffy
    • PWS Monitor
« Reply #77 on: November 01, 2019, 05:21:46 AM »
PWS monitor PRO 4.0.8
- fixed MIN for temperature
- fixed MIN for dew point
- changed wind MIN to gust MAX
- added up to 10 accounts to add
Download
https://play.google.com/store/apps/details?id=com.tools4monitoring.meteo.pws.pro
Offline superduty
« Reply #78 on: November 01, 2019, 08:51:26 AM »
Is there no longer a free version?
Or are the updates only for the pro version?
Sent from my SM-G973U using Tapatalk
Offline buffy
    • PWS Monitor
« Reply #79 on: November 01, 2019, 10:11:23 AM »
free version is still available. but this update is only for PRO version. free version will be also fixed
Offline buffy
    • PWS Monitor
App is not updating actual values
« Reply #80 on: January 08, 2020, 04:36:06 AM »
Since yesterday WU stopped providing current values in XML. we are working on fix.
Offline buffy
    • PWS Monitor
« Reply #81 on: January 08, 2020, 04:46:28 AM »
FAST FIX
without app updating from store:
1. remove your PWS in settings
2. add your PWS again
3. data should be actual
Sorry for this issue. We will update app in stores ASAP.
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
« Reply #82 on: January 10, 2020, 04:36:52 PM »
Unfortunately, deleting and re-entering the station ID does nothing. For example, the solar display is 0 Watt.
I purchased the APK for two smartphones.
Offline buffy
    • PWS Monitor
« Reply #83 on: January 10, 2020, 05:57:20 PM »
WU switched off one of feeds with values...
Anyway, please, try update to version 4.2.2 and let me know if this help you. I tried fix problems, but I haven't for example testing feed in imperial units.
Do you have solar sensor and you should see this value?
Sorry for this issue. I try fix what WU made...
Offline Rychu
« Reply #84 on: January 10, 2020, 06:07:50 PM »
I updated to 4.2.2. It's 0.00 - I'll check in tomorrow and let you know.
Offline buffy
    • PWS Monitor
« Reply #85 on: January 10, 2020, 06:09:31 PM »
OK. I need know about bugs. Few values are gone, but solar you should see.
thanks for feedback
Offline Rychu
« Reply #86 on: January 11, 2020, 12:59:07 PM »
I think it's ok  ;)
Offline Carne81
« Reply #87 on: January 13, 2020, 05:53:05 AM »
Good App! Are you planning to add some widgets?
Offline buffy
    • PWS Monitor
« Reply #88 on: January 14, 2020, 07:12:05 AM »
yes, I tried make some test and maybe it will be available like separate app widget. but now I made only few tests. Hope it will be possible.
Offline buffy
    • PWS Monitor
« Reply #89 on: January 30, 2020, 04:21:35 AM »
WU stopped again providing data values. Is this end of all 3rd party apps? my official manufacture app for my weather station is not working too. My data stopped at 2020-01-30 01:10:01. Now it's 10:18, no new data...
I bought my meteostation because of reading my data... I can't change sending data from WU to somewhere else. What should I do now? I don't want send my data to WU now, but I'd like still read it.
Offline superduty
« Reply #90 on: January 30, 2020, 10:36:04 AM »
I'm getting a data error and it's not updating info.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #91 on: January 30, 2020, 10:52:19 AM »
Same here
But WS view I'd fine
Offline awsum140
« Reply #92 on: January 30, 2020, 10:57:25 AM »
WU is screwing with, or maybe eliminating, APIs.  I think they view the data WE SUPPLY as their sacred property and only for use by WU.
If it's not a Boerboel it's just a dog.
Offline buffy
    • PWS Monitor
« Reply #93 on: January 30, 2020, 12:27:21 PM »
I have same error with your WU id... With my WU id I read only old data without error. Hope it's all because of WU maintenance.
Offline buffy
    • PWS Monitor
« Reply #94 on: January 30, 2020, 12:29:10 PM »
Same here
I tried WS view and I see same old data like in my app. Maybe I will try fix it by using APIKEY in app. But it will take time, data values are not same...
Offline buffy
    • PWS Monitor
« Reply #95 on: January 30, 2020, 12:31:41 PM »
yes, maybe. but more traffics are from weather stations to their servers. few api calls and sending data out can't ruin them. anyway they use OUR meteo data for their business.
Does anyone know api calls limit? I didn't find this information.
« Last Edit: January 30, 2020, 12:36:30 PM by buffy »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #96 on: January 30, 2020, 07:43:40 PM »
More "Rolling Brownouts" going on over there.
My WS View is fine.
Camera has been MIA for months.
Showed thinking spinner for a few hours today.
Now disappeared and I was able to add it back.
Will have to reboot cam with new key to test if actual upload happens.
Offline buffy
    • PWS Monitor
« Reply #97 on: January 31, 2020, 08:40:34 AM »
It looks that public PWS data api is gone. Source is empty. I'm sending to WU meteo data and their ecosystem is really unstable. I had meteo info on my website (it's gone). I made app for showing MY DATA (it's gone too). Why I spent so much money for PWS if only what can I do is giving my meteo data to WU (IBM)?
really bad... I'm working on new version of data loader. In the meantime, I will get a lot of negative points from angry users... everytime it's fault of developers, not service.
Offline buffy
    • PWS Monitor
« Reply #98 on: February 01, 2020, 05:08:11 AM »
Old public api sources are finally gone! They will not start it again, maybe for while. We should use APIKEY and another api sources. values are not same...
I made new version of Android app with new data loader. But you need to add your APIKEY. I'm not sure about api calls limits, that's why I'm affraid add to app my apikeys for better using.
We will see what happens
Version 4.3.0
- add APIKEY in settings
- 1/7 days chart data
- UV sensor is back if available
- better loader (faster)
In app there still could be some bugs. If you find any, please report to me, I will try make fast fix. I had no chance to check every situation and device. Thanks
« Last Edit: February 01, 2020, 05:10:39 AM by buffy »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #99 on: February 01, 2020, 08:30:25 AM »
Seems to work with the API key.
Only showing integers for temp, no decimals.
