Author Topic: Unable to connect to APRS servers for VPLive upload  (Read 4502 times)
Offline W3DRM
    • Emmett Weather
« on: November 05, 2011, 01:14:55 AM »
Two days ago my feeds to the APRS servers via VPLive started failing. I have made no changes to the software or settings but the data uploads stopped. Looking at the VPLive log file, I see that it is failing to connect to the APRS servers.
Has anyone else recently had a similar problem? This is baffling. I sent an email to Russ at the support staff for CWOP/APRS this evening and am awaiting a response.
You can see the data stop on Nov 2nd:
http://www.findu.com/cgi-bin/wxpage.cgi?call=W3DRM&last=240
« Last Edit: November 05, 2011, 01:17:31 AM by W3DRM »
--- RIPE Atlas Probe - 32849
Offline weatheroz
    • http://www.jimboombaweather.com
Re: Unable to connect to APRS servers for VPLive upload
« Reply #1 on: December 16, 2012, 06:46:52 AM »
Did you ever find an answer to this one ?
I had a HD fail, upgraded to win7, and noticed that things are no longer working for me.
Brendan
vk4blp
Brendan,
vk4blp
IRLP 6857 Echolink 672767
Offline W3DRM
    • Emmett Weather
« Reply #2 on: December 16, 2012, 04:50:45 PM »
Brendan,
Wow, that was over a year ago and yes, everything is working fine again. However, i don't remember what the fix to the problem was at the time. I suspect it may have been that the APRS server addresses had been updated and VPLive didn't pick up the correct addresses but, I really don't remember.
Have you checked your version of VPLive? Is it the latest (1.2.5.27). Also be certain you have VPLive set to automatically download the CWOP/APRS se3rver list from SoftWX. That can be found in the Settings | CWOP/APRS Settings menu item.
Offline weatheroz
« Reply #3 on: February 18, 2013, 05:59:52 AM »
Well I got all that working, but suddenly I've just noticed that it hasn't been uploading the data again. :(
I've noticed that now the status bar reads
Could not start APRS helper process
This is also in the logs too.
I'm running it as Administrator user now, but that didn't fix it.
Brendan,
vk4blp
Offline weatheroz
« Reply #4 on: April 16, 2013, 07:56:40 PM »
Still having troubles with this where the error log is full of :-
Brendan,
vk4blp
« Reply #5 on: April 16, 2013, 09:21:33 PM »
I noticed this week that I was not sending to cwop.
I had to switch to WD for that .
Offline Gretnawx
    • Gretna Weather Page
« Reply #6 on: April 17, 2013, 07:17:44 AM »
My CWOP uploads using VPLive also stopped working about a week ago.  WeatherLink works and so I've switched back to it for all my weather data processing and uploads.  The newest version of WeatherLink 6.0.3 while still archaic looking seems much more robust for the uploads to CWOP and Weather Underground with almost no failed uploads in the past week.  It is too bad VPLive is no longer supported as it was a really nice utility, but that happens with freeware/shareware.
There are 10 types of people in the world - Those that know binary and those that don't
