To muddy the subject....you say you made it 3 years before this happened....you may well make it another 3 years without a problem.
But...you told the WFL what address you want it to have, but the router assigns that, not an attached device. The only reason this is working is that you used the IP address the router has currently assigned to the WFL. If after the next time the router reboots (Comcast can cause this as well as you), the router gives another device that IP your WFL will not reconnect.
My advice is to set up an address reservation in your router using the WFL's MAC address. That way the ROUTER will always give the same address to the WFL after any reboot. You can put the same address in the WFL as static, or just set it to DHCP - either way will work.
