Ok the ISP had me change my resolver on the server to new servers.
So check-fetch-times.php?show=versions is loading fine now.
wxadvisory.php is showing <!-- Total process time: 0.0001 seconds --> so that looks better.
I changed get-aqi-rss.php from 134 to
https://feeds.enviroflash.info/rss/realtime/56.xml for Hartford, CT.
Everything was working good for a few hours and now getting a new batch of errors.
Warning: DOMDocument::load(): Opening and ending tag mismatch: meta line 27 and head in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 28 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): attributes construct error in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 33 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Couldn't find end of Start Tag script line 33 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 33 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): StartTag: invalid element name in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 38 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Opening and ending tag mismatch: meta line 25 and html in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Premature end of data in tag meta line 24 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Premature end of data in tag meta line 23 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Premature end of data in tag meta line 4 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Premature end of data in tag head line 3 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: DOMDocument::load(): Premature end of data in tag html line 2 in http://feeds.enviroflash.info/rss/realtime/56.xml, line: 42 in /home/weather/public_html/get-aqi-rss.php on line 37
Warning: Undefined array key 0 in /home/weather/public_html/get-aqi-rss.php on line 48
Warning: Trying to access array offset on value of type null in /home/weather/public_html/get-aqi-rss.php on line 48
Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/weather/public_html/get-aqi-rss.php on line 48
Warning: Undefined array key 0 in /home/weather/public_html/get-aqi-rss.php on line 58
Warning: Trying to access array offset on value of type null in /home/weather/public_html/get-aqi-rss.php on line 58
Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/weather/public_html/get-aqi-rss.php on line 58
Warning: Undefined array key 0 in /home/weather/public_html/get-aqi-rss.php on line 72
Warning: Trying to access array offset on value of type null in /home/weather/public_html/get-aqi-rss.php on line 72
Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/weather/public_html/get-aqi-rss.php on line 72
And now these as well...
Warning: Undefined array key 0 in /home/weather/public_html/ajax-dashboard6.php on line 2028
Deprecated: round(): Passing null to parameter #1 ($num) of type int|float is deprecated in /home/weather/public_html/ajax-dashboard6.php on line 2028
Mar-14
Warning: Undefined array key 0 in /home/weather/public_html/ajax-dashboard6.php on line 2036
Warning: Undefined array key 1 in /home/weather/public_html/ajax-dashboard6.php on line 2042
Deprecated: round(): Passing null to parameter #1 ($num) of type int|float is deprecated in /home/weather/public_html/ajax-dashboard6.php on line 2042
Mar-15
Warning: Undefined array key 1 in /home/weather/public_html/ajax-dashboard6.php on line 2050
Warning: Undefined array key 2 in /home/weather/public_html/ajax-dashboard6.php on line 2056
Deprecated: round(): Passing null to parameter #1 ($num) of type int|float is deprecated in /home/weather/public_html/ajax-dashboard6.php on line 2056
Mar-16
Warning: Undefined array key 2 in /home/weather/public_html/ajax-dashboard6.php on line 2064
I wish I had a clue of what was going on as other then this I didn't change anything....
