Author Topic: New Firmware  (Read 1324 times)
Offline Cutty Sark Sailor
New Firmware
« on: June 08, 2016, 09:09:15 AM »
Tobi's released 8.0b5 firmware for RED and BLUE...
Couple of known filter setting bugs in it, he'll fix later...
Make sure you get right firmware for system you have!
Get It
Have been running the firmware awhile on BLUE, works great... no issues.
Installed on RED last night, no issues. Works great.
Except for a couple of minor 'glitches, Tobi will likely release this version as stable version next week...
so test and report any issues or confusion on the Blitzortung firmware thread, INTERNAL board.
(Tobi's locked into real world demands until next week, so post what you notice so he can catch up quickly...)
Fixes since RED / BLUE Beta 8.0b3 (Note that RED skips b4 - b4 was BLUE only)
* filter settings visible when solder bridge J0 closed [BLUE]
 * description for input selection instead of input numbers [BLUE]
 * sending information about inputs and filters to computing server [BLUE]
 * minor changes in server urls for remote config
 * lowered max opened and listening tcp connection
 * factory settings/debug mode with BOOT1 button: press and hold for 2s/10s just after reset [BLUE]
 * fix: raised stack memory size and added collision check
 * fix: network LED stayed off after blinking, even when status is good [BLUE]
 * fix (maybe): threshold/signal detection stopped after some when time in manual mode w/o noise adaption
 * fix: minor issue that click on Firmware Update button had no effect
 * switched to GCC ARM Embedded 5.3 2016q1 toolchain
« Last Edit: June 08, 2016, 09:17:09 AM by Cutty Sark Sailor »
