Author Topic: Looking For A Historical Calendar View Of Forecatsed Versus Actual Weather Data  (Read 8779 times)
Offline textech
    • Arnold Family Weather Station
I am looking for a way to display Forecast Weather Data (Temp&Precip) along with the Actual Data in a Calendar format.
I gather the Forecast Data for my area using Virtual Weather Station out 5 days. I gather the Actual Data with my home weather station.
I would like to be able to display the 5 Day Forecast Data along with the Historical Actual Data on a Calendar by month. This would provide me with a good view of the Forecasted Temp&Precip right along with the Actual Temp&Precip for the day.
So the calendar would build throughout the year gathering and displaying the Forecast and Actual Data. I would like to be able to click on any historical month within the year to get a look at Forecast versus Actual.
Does anyone have an interactive calendar view that could be tweaked for something like this?
Wayne Arnold
Arnold's Family Weather Website
http://textech.drivehq.com/
Offline iisfaq
  • Christchurch Weather Live
It is an interesting idea but I think quite a bit of work to get the calendar accurate.
I guess one of the problems that I see with this is at what point is the forecast considered the actual forecast for comparison reasons?
For example I am using WXSIM to generate a forecast for me every hour. At what point do you compare the forecast against actual?
3 hours prior to the "compare" time, and what is the compare time? 9am, 3pm, both?
My forecast generally does not change a lot the same day but small changes do occur during the day.
Do you break down the day into 2 halves? or maybe night and day? or Morning, Afternoon, and Evening?
Do you have any thoughts on how you want the data displayed? Would you have a temperature graph displayed? the list is almost endless.
I know most people do not have very accurate data for cloud as it is hard to estimate clouds without additional hardware.
I have a hardware cloud sensor (quite cheap) and I am trying to get more accurate cloud readings for my site as I use its data to calculate my current conditions which changes every minute.
It has a sensor temperature and a sky temperature. But on a really hot clear day the sensor is very high like 40-60 degrees C and the sky can be 10-15C. But on a mild day with no clouds the sensor can be 25 degrees and the sky in the negatives.
I am currently trying a matrix of cells 19 wide by about 30 long ranging from -35C to 55C along the x axis (sensor temperature) and -38C to 60C along the y axis (sky temperature). I then specify the cloud value based on XY coordinate. It is a bit hit and miss but it may work out better than my previous approach just comparing the values.
So even determining that it was "Cloudy" all morning is quite a bit of work - some of this raw data can bee see at http://weather.crowe.co.nz/SkyClarity/
Rain is another issue, at what point do you say it "rained" today 0.2mm, 1mm? More than xx minutes?
Interesting idea though for a calendar.
Chris
Offline textech
I have my station setup to reset collected weather data daily at midnight. I was thinking that having the 4:00pm NOAA Forecasted Data captured by my weather station software and logged to the historical calendar view daily would be what I wanted.
You are correct in saying that the forecasting data changes hour by hour, but I was looking for a general comparison view of the general forecast versus the actual data captured by the weather station. The forecasting data captured from NOAA on 4:00pm Monday for Tuesday will most likely change some, but from the 4:00pm forecast I would be making a good determination about my next days activity schedule so that is the comparative data I would like to capture. Others may want to capture their forecasting data from a different time frame for historical references.
I just thought it would be neat to have a historical view of forecasted weather versus actual captured weather from a single point in time on a five day basis. Most people tell me that weather forecasting is mostly inaccurate. I think with a tool like this we could see the reality of our local forecasting that posted versus actual.
Wayne Arnold
I'd use an SQL database to provide the repository for this "hindcast"  There are already examples out there of such functionality.
