Author Topic: Moving a PWS  (Read 1218 times)
Offline Randall Kayfes
  • Weather - Photography - Astronomy - Computer Admin
    • Arizona Kaymann
Moving a PWS
« on: December 01, 2018, 11:05:15 AM »
Greetings,
So I moved (16 miles as the Crow Flies) and took my PWS with me so I took the following steps;
  • Changed the Latitude and Longitude in my Davis Console
  • Changed the Location on WU and got a new WU ID (successful)
  • Changed the Location on findu and got a confirmation email (successful)
I Checked the location on forcast.weather.gov and the location is still found at the old location but the Latitude and Longitude is correctly list to the new location...
Did I miss a step here in the process two other station move were completed successfully given the above taken steps...
Any ideas why my location hasn't changed for NWS map?
https://forecast.weather.gov/MapClick.php?lon=-111.05851113796234&lat=32.418732790609056#.XAKxKGiM9aQ
Randall
Offline SteveFitz1
    • Tyler Texas Weather
Re: Moving a PWS
« Reply #1 on: December 01, 2018, 11:17:25 AM »
Randall,
It looks like the location in your NWS link is Lat: 32.418732790609056 and Lon:-111.05851113796234, but the CWOP location being shown for DW4959 is Lat: 32.18523, Lon: -111.0772. I'm not sure which one is your old and new locations, but my guess is the CWOP location info hasn't propagated your changes through the system yet.
Steve
Offline Jstx
  • Baby the Rain Must Fall
Re: Moving a PWS
« Reply #2 on: December 01, 2018, 12:13:29 PM »
Think it can take up to a week to work changes through CWOP-MADIS-NWS.
    • Arizona Kaymann
Re: Moving a PWS
« Reply #3 on: December 01, 2018, 06:38:53 PM »
Thank you all - I went to the MADIS map found my station at the old location also the LAT and LON listed also the old values.
It has been 5 days and CWOPS already has it all down correctly so I guess I will wait a little longer.
It just seemed to take so little time in my past moves - I will be more patient.
Randall
Re: Moving a PWS
« Reply #4 on: December 02, 2018, 07:38:38 AM »
Decimal Degrees (Latitude and Longitude) with more than 6 digits past the decimal are pretty much unnecessary. Get rid of unnecessary complexity.
https://en.wikipedia.org/wiki/Decimal_degrees#Precision
With 6 decimal places you have a precision of about 4 inches. You don't need more than that for weather station placement. With 7 decimal places you are at better than half an inch precision.
UPDATE: Just realized that the Latitude / Longitude in the link above was created by a map click on NWS site. I thought at first it was what was being used by the station. I'm surprised by this behavior of the NWS site.
« Last Edit: December 02, 2018, 07:54:29 AM by galfert »
    • Arizona Kaymann
Re: Moving a PWS
« Reply #5 on: December 02, 2018, 10:32:26 AM »
Well MESOWEST finally picked up on the change so their is hope NWS is next  :grin:
Randall
« Last Edit: December 02, 2018, 10:41:44 AM by kaymann »
Offline Jstx
Re: Moving a PWS
« Reply #6 on: December 02, 2018, 11:00:17 AM »
Randall
Well, MesoWest-Utah pulls their data from MADIS, which for most of our PWS feeds, ingests it from CWOP-APRS. MADIS is NOAA/NWS, so any moment now it'll pop up there.
Offline stoat
Re: Moving a PWS
« Reply #7 on: December 02, 2018, 01:05:04 PM »
Station updates for the webpage only get pushed once a week (on Thursdays) so you are probably looking at another 4 days.
Offline Old Tele man
  • Singing in the rain...
Re: Moving a PWS
« Reply #8 on: December 02, 2018, 07:53:40 PM »
Randall
Kaymann -- Looks like NOAA/NWS/MADIS has activated your move because NWS/TUC now locates you out west by Tucson Estates (moving 'closer' to the sunsets?).
« Last Edit: December 02, 2018, 07:57:57 PM by Old Tele man »
    • Arizona Kaymann
Re: Moving a PWS
« Reply #9 on: December 02, 2018, 08:24:17 PM »
Greetings and thanks everyone and I apologize for the impatience... If I had only waited one more day. OTM thanks again for Barometer help I while back. I used your suggestions to get my Barometer squared away from the get go this time.  BTW the Desert views are killer from my new location so when I get a little more settled in I will start posting pictures again...
    • Arizona Kaymann
Re: Moving a PWS
« Reply #10 on: January 04, 2019, 10:05:40 AM »
Well after two months the NWS has again placed my PWS on the map. Now when someone in my area (including me) zooms into my neighborhood they see my weather station - complete with forecast as well!
https://forecast.weather.gov/MapClick.php?lon=-111.0772&lat=32.1852#.XC910lyM9aR
If only I could convince CWOP to change the location name to Tucson instead of Marana... Oh well.
Randall
Re: Moving a PWS
« Reply #11 on: January 04, 2019, 10:10:23 AM »
Welcome back DW4959 Marana (D4959)
Re: Moving a PWS
« Reply #12 on: January 04, 2019, 02:49:46 PM »
Not sure, but probably that's something our WFO (IT Officer, Evelyn?) would have to do. Here's their # should you wish to call 520 670 5162.
