Author Topic: One ISS, Two Consoles, Two Readings  (Read 708 times)
Offline WXman
  • Stormdawg
« on: July 04, 2020, 11:58:36 PM »
I have one ISS sending data to two consoles on channel 2. Both consoles show temperatures and humidity that are different. What would cause this? I'm in a rural area with no other weather stations near me. I'm confused.
B.S. in Meteorology/Climatology
38.01977N, 84.83486W
Davis Vantage Pro 2 wireless station
AcuRite 5-n-1 w/ WiFi reporting to WU
Re: One ISS, Two Consoles, Two Readings
« Reply #1 on: July 05, 2020, 12:16:12 AM »
Are the clocks set to the exact same time?
« Reply #2 on: July 05, 2020, 08:30:20 AM »
Calibration difference - check calibration.
Even if set to same channel maybe one is picking up neighbor's station - change channel on ISS.
« Last Edit: July 05, 2020, 09:05:09 AM by galfert »
Offline WXman
  • Stormdawg
« Reply #3 on: July 05, 2020, 08:51:25 AM »
The clocks are maybe a few minutes apart. Would that matter much?
I'm in a rural area. Nobody else within miles has a Davis station.
Offline johnd
« Reply #4 on: July 05, 2020, 08:55:29 AM »
Give us some examples of the T/H differences. As galfert says, are you sure that one or other console doesn't have eg a temperature calibration offset?
Cambridge UK
Offline WXman
  • Stormdawg
« Reply #5 on: July 05, 2020, 02:36:47 PM »
The ambient temperature is running about 1゚ to 1.5 degrees different between consoles and the dew point temperature is 1゚ different between consoles.
 I will check the calibration to make sure both are 0.
Offline WXman
  • Stormdawg
« Reply #6 on: July 05, 2020, 02:45:27 PM »
Well that was it. I don't remember ever having done it, but one console had a -1 calibration for outside temp which of course throws off the humidity. Doh!! It's always the simple things that I overlook. Thanks everyone!
« Reply #7 on: July 05, 2020, 03:30:08 PM »
But if you have a new replacement temp/humidity sensor you would need the -0.9°F adjustment on both consoles to be accurate. New sensors require this adjustment (for some console revisions). You wouldn't want it to be zero.
Read about this on this page:
https://www.scaledinstruments.com/shop/davis-instruments/parts/vantage-pro2-parts/temperature-and-humidity-sensor-parts/davis-7346-070-pro2-digital-temperature-humidity-sensor-sensiron-sht31/
« Last Edit: July 05, 2020, 03:32:27 PM by galfert »
Offline WXman
  • Stormdawg
« Reply #8 on: July 05, 2020, 04:51:43 PM »
Thanks for the info.
Offline WXman
  • Stormdawg
« Reply #9 on: July 05, 2020, 09:38:54 PM »
So after reading that article it sounds like the calibration only needs to be done if you have incompatible transmitter board and sensor. Since my ISS is new with factory components I shouldn't have to do that at the console right?
Offline johnd
« Reply #10 on: July 06, 2020, 03:32:18 AM »
Correct.
Cambridge UK
Offline WXman
  • Stormdawg
« Reply #11 on: July 06, 2020, 08:38:36 AM »
Thanks.  Not sure how that happened, but glad I finally discovered it.  Funny thing is, I always thought my AcuRite station running next to it was reading high and it turns out it's pretty close afterall.   :lol:
