Author Topic: Help for my website  (Read 3025 times)
Offline wvdkuil
  • Wim van der kuil
Re: Help for my website
« Reply #25 on: May 16, 2019, 03:24:32 AM »
I tried to configure the whole site from scratch, inserting all the APIs but it doesn't work.
At this point either I solve the problem of empty spaces in the realtime.txt file or abandon the project. I'm just sorry I already paid the host
PLEASE contact your provider
Show them this post or send them the screenshot p509.jpg which i attached.
All you work did and all your time results in a working site BUT it is far to slow and there are unneeded errors.
See the attached screenshot.
Your provider allows your site far to few resources.
The 509 errors come form them. Not from your scripts
When a free  account  old link removed https://pwsdashboard.net/pws10/index.php  can run this template very quickly without any problem, it should be their concern that you can not run it with a paid-for account.
It is their problem (their settings)  they should solve. Or they should tell you how to use your cPanel to solve it yourself.
There are a total of 6.048 websites with the same IP-address 217.64.202.205 as yours. I visited a few and they seem to work normal.  Ask the support person of your provider what you can do to get a decent performing website.
« Last Edit: April 29, 2020, 09:20:46 AM by wvdkuil »
Offline MatteoPV
« Reply #26 on: May 16, 2019, 04:23:07 AM »
After applying the tips you gave me and editing the realtime.txt file recommended by PaulMy, the site works. Now for 6 hours I can't touch anything because I upgraded my host to the higher performing version. However, I believe it will work. I see what happens towards evening
Offline MatteoPV
« Reply #27 on: May 16, 2019, 06:32:39 AM »
Before, however, I noticed that everything worked but I didn't have the daily graphs of temperature, wind, rain, etc. To have the graphs I have to do ????
Offline wvdkuil
  • Wim van der kuil
« Reply #28 on: May 16, 2019, 07:06:41 AM »
For the graphs it is the best and easiest way to upload to WU also.
That way you have access to your own data directly form their database.
And you get a free api-key to use for a 5 day forecast. Then you can choose between the DarkSky-forecast and the WU-forecast based on the quality for your specific region.
Offline MatteoPV
« Reply #29 on: May 16, 2019, 08:49:48 AM »
I did not mean that. The hourly, daily and weekly forecast is already taken and seems to me to be correct. I meant the graphs of my data ... wind, temperature, rain. If I click on the day or month buttons of the relevant boxes of my live data, I get a box but without a graphic
Offline wvdkuil
  • Wim van der kuil
« Reply #30 on: May 16, 2019, 09:01:51 AM »
Most of the blocks display your current data coming from realtime.txt or from wl.com.
Some display forecast or current conditions => they use DarkSky to get relevant data
 = = => you can use other forecasters also, such as WU if you have an API-key
The pop-ups will show the graphs a few days after you start uploading to WU.
They need to get their data from somewhere and the easiest choice is WU.
Therefor you have to set the name of your station in the easyweathersettings.
If you decide not to upload (why?) you will have to follow a few steps to define a database-table to store 1 day of weather measurements.
And then run two extra cron-jobs each day.
Offline MatteoPV
« Reply #31 on: May 16, 2019, 09:12:01 AM »
OK. Now I wait for the site to have migrated to the new server and then start watching
Offline wvdkuil
  • Wim van der kuil
« Reply #32 on: May 16, 2019, 09:15:29 AM »
But you should not wait to make an account at WeatherUnderground and start the uploading with your wiFi logger.
All that can already be done.
Then go to your stationspage on the WeatherUnderground site to check if your data arrives every so many minutes.
Offline MatteoPV
« Reply #33 on: May 16, 2019, 09:23:57 AM »
https://www.meteocamporamoso.it/pwsWD/index.php
Thanks to the advice you gave me the site is finally working ..... even the graphics are coming. My station is recently online on WU.
I still have a couple of things to fix, redirects that I had set on the WL page and the input errors that I might talk about with the host manager
Offline txweather.org
    • Texas Weather
« Reply #34 on: May 16, 2019, 10:48:50 AM »
MatteoPV,
Your SSL cert is invalid. I would fix that if you can.
Offline MatteoPV
« Reply #35 on: May 16, 2019, 11:38:43 AM »
MatteoPV,
Yes. Now see if it is my wrong setting or if I need to call in the host manager
    • Texas Weather
« Reply #36 on: May 16, 2019, 11:41:38 AM »
MatteoPV,
Your issue is here:
Common Name (CN)   mediaimmobiliareaversa.com
The common name does not match your domain. I would contact whom ever created the cert for you and have them fix it or just regenerate a new cert with the right domain.
Good luck!
Offline MatteoPV
« Reply #37 on: May 16, 2019, 11:52:12 AM »
MatteoPV,
Your issue is here:
Good luck!
I've communicated everything to the host manager, we'll see what they respond to. Thanks for the informations
Offline MatteoPV
« Reply #38 on: May 18, 2019, 12:14:11 PM »
Offline MatteoPV
« Reply #39 on: May 18, 2019, 12:52:20 PM »
I have a question.....
Now the site is online and I'm super happy !!! But I would never lose my settings .... which file should I save to always have my settings safe ????
Offline wvdkuil
  • Wim van der kuil
« Reply #40 on: May 18, 2019, 01:03:16 PM »
(1) Make a copy and (2) download the copy to your PC:  w34_settings1.php
Offline MatteoPV
« Reply #41 on: May 19, 2019, 03:13:44 AM »
This morning from a graph error. Clicking to see the hourly or daily graphs of the weather info from error
Offline wvdkuil
  • Wim van der kuil
« Reply #42 on: May 19, 2019, 04:43:55 AM »
sometimes the WU servers return nearly empty data, but that data is then cache.
The WU site is stil in a transition phase.
Most of the times the graphic work ok after
@ALL
I am off on a two week vacation until June 2.
Nearly no internet.
