Author Topic: Affordable Temperature-Only Internet-Connected Station for a Snowy Location  (Read 644 times)
Offline TheMuscovite
Basically what the title says.
We share a family ski cabin.  We'd like to know what the temperature is there both when we're away, and while we're there. I'd also like to not spend more money than I need to.
The cabin has reliable internet.
Because of the snowfall, terrain and trees, it's impractical to measure windspeed.  Measuring snowfall would be nice, but is too complex for the investment we'd like to make.  So, really all I'm going for is temperature.
I'm looking for an affordable, reliable unit that will let us know what the temperature is remotely, or by glancing at the wall while we're there.
We use Google Home to manage other parts of the cabin while we're away, so integration with Google Home would be nice, but I haven't been able to find an outdoor temperature sensor that integrates with Google Home.
Offline vinceskahan
    • home site
Ecowitt gateway and outside sensor would be under $50 or so.
WeeWX sites:
  Davis VP2+DFARS to a pi4
  EcoWitt GW1000, WH32 outdoor T+H, multiple WH31 indoor T+H, WH51 soilMoisture, WH34 soilTemp (pi4)
  Davis AirLink (inside)
  PurpleAir (outside)
Home site:        https://www.skahan.net/
Wunderground: KWAFEDER15
PWS:                KWFEDER15
CWOP:              CW6881
Thanks for the suggestion.  It looks like this GW1104 kit at Amazon would get me what I need, for less than $40?
Offline alanb
You will probably want some type of radiation shield for the temp sensor since you are installing outside. That will keep it dry and help mitigate temp spikes from direct sun. I use this one for a WH31 and it works well for me: https://www.amazon.com/AcuRite-06054M-Tempature-Humidity-Radiation/dp/B01M64ISDE. I would also recommend Energizer Lithium batteries for the cold temps.
« Last Edit: January 24, 2024, 01:12:53 PM by alanb »
Alan - Ambient WS-2000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
Offline vinceskahan
    • home site
Yup.
You can save a few bucks there it seems by buying the gateway and sensor separately.   The gateway only would be enough for remote monitoring.   Add the sensor(s) for the nice display they have.   For integrating with Google Home or other things you could run weewx on a small raspi if you wanted to do a little IT adventure.  Works great.   I integrated mine with Home Assistant and did a dashboard that runs on a $40 Kindle Fire HD.
I have a gw1000, one outside sensor, and 5 inside sensors at this point to monitor various rooms.  For the winter I guess gateway for inside + outside sensor would even be plenty.  Maybe add an inside sensor for its display when you're there.   Batteries last years.
WeeWX sites:
  PurpleAir (outside)
PWS:                KWFEDER15
CWOP:              CW6881
Offline vinceskahan
    • home site
You will probably want some type of radiation shield for the temp sensor since you are installing outside. I use this one for a WH31 and it works well for me: https://www.amazon.com/AcuRite-06054M-Tempature-Humidity-Radiation/dp/B01M64ISDE. I would also recommend Energizer Lithium batteries for cold temps.
I just put mine in a shade-almost-always location in a $5 birdhouse that I drilled a bunch of holes through for airflow and painted gloss white.  It's been working great for years.  But agree.  Keep the sensor out of direct or reflected sun.
WeeWX sites:
  PurpleAir (outside)
PWS:                KWFEDER15
CWOP:              CW6881
Thanks for all the suggestions.
I've ordered the GW1104 combo, UV protector, and the WH0298_C display for viewing the outside temp easily from within the cabin.
Getting off-topic from my original question, but I've also got a WS90-based system on the way for our home ~120 miles away.  Is there some kind of setup I should be thinking of that would integrate the management of both locations, or will it be easier to just treat them as two totally separate systems?
