Author Topic: Temperature/Humidity SHT15 question  (Read 385 times)
Offline onedart
« on: February 24, 2020, 01:49:05 PM »
Hi.
I believe that my temp/humidity sensor has gone bad as the Humidity reads 1% most of the time, I have a SHT15 sensor installed, if I install a SHT31 is there anything I need to do in terms of sensor calibration?
Thanks in advance
Offline Tornado12
Re: Temperature/Humidity SHT15 question
« Reply #1 on: February 24, 2020, 04:21:44 PM »
Yes, depending on the date your ISS was manufactured. Go to this page and scroll down and read - it goes over everything you will need to know. You can also purchase the unit at this link
https://www.scaledinstruments.com/shop/davis-instruments/parts/vantage-pro2-parts/temperature-and-humidity-sensor-parts/davis-7346-070-pro2-digital-temperature-humidity-sensor-sensiron-sht31/
Offline onedart
« Reply #2 on: February 24, 2020, 04:34:42 PM »
Thanks for your help
« Reply #3 on: February 24, 2020, 05:36:52 PM »
Since you are in the UK, perhaps this is a better source.
https://shop.weatherstations.co.uk/7346070-std-vp2-temphum-sensor-2006-on-1747-p.asp
