Miscellaneous Debris => Tech Corner => Topic started by: phobos on September 18, 2022, 02:33:43 PM
https://www.digikey.es/reference-designs/en/sensor-solutions/temperature-sensing/2005
I just want a simple but very accurate temp + humidity device, I was recommended the SHT31 sensor, this thing has it. Im assuming this is ready to run and you don't have to do anything, you just press a button and it will work.
If anyone knows some alternative that's more "mainstream looking" that would do but I don't want to sacrifice accuracy for aesthetics.
Looks like that unit is discontinued.
New item:
https://www.digikey.ca/en/products/detail/sensirion-ag/SHT4X-SMART-GADGET/14318392
New item:
So this is even more accurate than the old sensor?
SHT4X is used in any other better looking censors? I don't want to have that battery on the outside, with humidity pcbs and stuff can be deteriorated, I would like a case for this so its protected.
up
What do I buy?
I still haven't bought anything
