Author Topic: Video CApture image file location?>  (Read 3336 times)
Offline n9lya1
« on: June 16, 2009, 04:54:17 PM »
Hi all New to IS...
Looks very nice.. Where does the Image Salsa Video Capture save the *.jpg file.. I am unable to locate the images saved file.. All I can find is the demo Edition image...
I am running IS on XP.. With VWS....
Many thanks Jerry
Offline unclemoosh
  • Geaux Saints!
    • Frances' Weather
Re: Video CApture image file location?>
« Reply #1 on: June 16, 2009, 05:35:27 PM »
You set the location in the Canvas Properties.  Use the tabs marked Fixed Save and Sequential Save.
Offline n9lya1
« Reply #2 on: June 17, 2009, 04:19:13 PM »
Hi Unc...
All I find at those two locations (I am sure its something I hosed up) is Blank White screens using my KEY and Demo Edition on a white background with the demo version.....
The Video is not getting to the right place or I do not know where it is??? I have captured the video with the video capture setting... Just not sure where it saves it...
Thanks Jerry
Offline unclemoosh
  • Geaux Saints!
    • Frances' Weather
« Reply #3 on: June 18, 2009, 10:31:54 AM »
I am not sure what you mean by "video capture setting."  Do you mean "video feed setup?"  Did you create a canvas and set the graphics to capture your video feed?  If so, you should see the "fixed save" tab that allows you to set the location where ImageSalsa saves the canvas.
Offline n9lya1
« Reply #4 on: June 18, 2009, 04:04:17 PM »
Yes that all works... The Canvas it saves is BLANK Pure white no video....
Yet the Video feed setup shows a moving active picture....
How do I find my picture to get it on the canvas... I know where to put the path to the picture.. But I cannot find any .jpg or bmp files of my cameras view...
Thanks I hope that helps explain it?????  If not we are getting close... Jerry
Offline unclemoosh
  • Geaux Saints!
    • Frances' Weather
« Reply #5 on: June 18, 2009, 04:11:01 PM »
There is a tab on the Canvas Properties labelled "graphics."  That is where you put in the data to use the video feed and how often to update it, the size and other attributes.
