Weather Software > Cumulus
CumulusMX upload question
PaulMy:
CumulusMX should be able to process that, and many more, at the usual 5-min interval along with the usual realtime FTP. With FTP logging enabled in settings you can check your MXdiags file and see what errors or messages are logged. Your Cumulus MX b3043 version is quite old and Mark has made a lot of changes since that version, including more details in MXdiags.
I process 13 files at 5-minute interval and 3 realtime at 10-seconds and do see the occasional error for the realtime FTP like
--- Code: ---2021-12-06 08:48:11.957 FTP[170]: Error uploading C:\KomokaWeather\CumulusMX\web-additions\realtimetagsT.phptmp to public_html/cumulusmx/realtimetags.php : Unable to identify the local data socket: Address already in use
--- End code ---
but the rest seem fine.
mkutche:
--- Quote from: PaulMy on December 06, 2021, 10:52:24 AM ---CumulusMX should be able to process that, and many more, at the usual 5-min interval along with the usual realtime FTP. With FTP logging enabled in settings you can check your MXdiags file and see what errors or messages are logged. Your Cumulus MX b3043 version is quite old and Mark has made a lot of changes since that version, including more details in MXdiags.
--- End code ---
--- End quote ---
After I switched servers everytime it tried to upload and failed CumulusMX would delete CUTags.php and 5 other files that couldn't upload.. then 5 minutes later they reappeared.. I soon fixed that.. Yea I know he has a new version out there just been too busy to update it. Is it easy to do?
PaulMy:
--- Quote ---Is it easy to do?
--- End quote ---
Yes I would say it is easy to do, but then I have been keeping up with the changes so becomes second nature...
Copy all unzipped files/folders in a new CumulusMX folder.
Copy in your existing \data and \Reports folders to the new install.
Copy in the existing Cumulus,ini file to the new install.
If you have your own edited template (T) files in your \web folder copy these to the new \web folder. If you are using the original Cumulus web template you will need to become familiar with the changes in the current default web pages and determine what changes you need to make.
There has been a lot of changes since your b3043 and most are just ongoing upgrades and new features. The Updates.txt file with the zip will show the full list of changes for each build.
A latest release change is CumulusMX now uses .Net Framework 4.8 (previously 4.5.2) and you would need to update if you don't already have 4.8.
With all the changes and new features it is good practise to go through each settings page and make sure the things you want are set and enabled as needed.
DW7240:
I have recently updated my CumulusMX, I do this as the updates come through, for some reason when CumulusMX is now running there are no updates to software, I have not changed any settings, just done the normal copying of files and uploaded as usual. Now if I manually invoke an update, everything is fine, just no updating every 5 minutes from the regular update schedule. Not sure what's wrong, any advice would be great.
Thanks in advance.
Nick. dw7240.com
Wow, further investigation has told me that there are extra settings in the update, namely in the Station Settings - Common Options - Sensor Check section, this I just ignored, but at present my Wind Sensor is off due to Station New Setp Up, but after switching the sensor check off the software now updates like it used to. Word to the wise - Check the updates for new settings - Can eleviate a sore head !!
Nick.
PaulMy:
Hi Nick,
Have you gone through all the Internet Settings, including Normal Interval Settings, etc.?
Some default settings have changed through the various version updates.
Are you uploading more than the Extra web files CUtags for the Saratoga template?
Which files re not updating?
Is there anything in MXdiags during the 5-min interval period?
[#] Next page
[*] Previous page
