Author Topic: SaratogaWX Blitzortung build diary.  (Read 14313 times)
Offline scarecrow93
Re: SaratogaWX Blitzortung build diary.
« Reply #50 on: October 09, 2013, 08:20:58 AM »
What gain are you running at?  If you're running at 10/4, under the current weather situation you're not going to get much.
When I first started my test on the 12 inch (30 turn, 18ga wire)...I started off at 10/10 and ended going up from there.
I just built an 8 inch (45 turn, 18ga wire) ball antenna on Friday to see how low I wanted to go in regards to the size.  The starting gain was much higher...around 16/16.
I'd probably start at 16/10 with yours and go from there.
Lance
Huntingtown, MD  #724
~Lance
#724 - Huntingtown, MD(Aug 2013 - Feb 2014)
Owings, MD(Feb 2014 - Feb 2015)
Annapolis, MD(Late Feb 2015)
« Reply #51 on: October 09, 2013, 11:05:00 AM »
Hi Lance,
Thanks for the gain advice -- I will crank up the gain as soon as I can isolate where the strange 60Hz spikes are coming from.  I've tried running higher 10:4, but currently, it only moves the controller into interference mode due to the false-positives provided by the spikes :(
Best regards,
Ken
Offline W3DRM
    • Emmett Weather
« Reply #52 on: October 10, 2013, 12:18:11 AM »
Ken,
Based on what I've experienced in the ham radio arena, sometimes, when attempting to locate an interference source, you will get better results by rotating the antenna to get a null in the readings. Nulls tend to be sharper (narrower due to them being lower in amplitude) and thus easier to find than a peak in signal.
I would look for a wall-wart (transformer used for all kinds of devices today - ie, laptop power supply, cell-phone charger, etc, etc), some kind of light dimmer or even the door-bell transformer to be your problem source. Do you have lamp in your door-bell button outside? All of these things could be sources of interference. Is this 60Hz signal present day and night or just at some particular time of day?
You may also want to begin turning off the circuit breakers for different areas in your house. That would help narrow down the location of the circuits causing the problem. Sorry, I know that means resetting your digital clocks but...
Good luck finding this elusive signal...
--- RIPE Atlas Probe - 32849
« Reply #53 on: October 10, 2013, 06:49:09 AM »
I would try using an AM radio to see if you can find anything. I have had mixed results with this, sometimes the radio finds noises that are not related to the lightning detector response.
I have used several different "sniffers" and have been able to eliminate some noises. I have an infrequent severe noise of unknown origin.
I noticed that my "green" detector responded and went into interference mode when the wife was running the vacuum cleaner. It could be a motor. Cutty has night-time outside light problems. Unfortunately, we live immersed in RFI from a lot of sources. Best of luck tracking them down, W3DRM has some good advice there and should give you some ideas.
Greg
Offline dfroula
« Reply #54 on: October 10, 2013, 09:36:17 AM »
I found the best sniffer for noise detection is the amp itself. Try connecting the monitor pins on the amp to a stereo headphone jack and plug the amp into a high-impedance input audio amplifier and listen to the signal. It is very easy to distinguish normal low-level 60 Hz background hum from noise from motors, 60 Hz harmonics from a bad "wall wart" power cube or other sources. With stereo earphones and each antenna connected to left and right channels of the amp, the nulls from the antennas are a very good way to trace the direction and type of interference. I used a simple "CMOY" headphone amplifier for the purpose. The CMOY is a simple single-chip headphone amp. Try Googling for the schematic. A PC soundcard would work, but then you are dealing with processor noise from the computer. An old set of PC powered speakers may work well.
Don
Greg
Offline W3DRM
    • Emmett Weather
« Reply #55 on: October 10, 2013, 01:00:55 PM »
Here's a link to the CMOY article. This site includes a complete, and detailed, description of the CMOY amp and a full listing of where to get the parts. It appears to be well done and should be easy for anyone to build.
« Reply #56 on: October 10, 2013, 03:04:26 PM »
That circuit has a gain of only 11. (1+(10k/1k)). Just less than 21dB.
Is that enough to hear anything?
It might be for a strong enough noise source. If the amp remains stable, you could increase the 10K feedback resistor to get more gain.
Greg
Offline rlee171
« Reply #57 on: November 22, 2020, 08:16:23 PM »
This thread ended without a resolution. What did Ken finally find to remedy the problem?
Davis VP2
Blitzortung Stations: 1387  1445  2315
Cumulus
GRLevel3
« Reply #58 on: November 22, 2020, 10:50:03 PM »
Oh, this was 7 years ago.. I don't rightly remember what I did to get it all working again.  The controller box was relocated (and dual ferrite antennas relocated) a bit within the garage and that seemed to fix the 60Hz issue I was having.
