So here goes.
Just fixed my Envoy antenna after I noticed that my wireless data had lots of dropouts and poor signal quality. I damaged the original coax, bad me, so it needed to be replaced. Got new antenna, Thanks Ryan, and installed it. Also found some fresh Duracell 123 batteries and changed those out on the ISS and the 6332 wireless anemometer transmitter up on the roof. Signals improved too almost perfect. ISS is using id1 and 6332 is using id2. So now for what is causing interference.
I suspect it is the gas meter causing the interference. Gas meter has been modified with the wireless mesh technology and I suspect it uses the 902-928MHz band. It usually happens at night on the hour or 1/2 hour. Never had this prior to mainly the gas meter mod which happened a year ago. I have also noticed when we are not using gas, no issues with signal. I am suspecting gas meter is culprit because it is in front of house and my Envoy is in a back room for total distance of 5' from console and 10' from Envoy. Power meter is 2' from envoy on outside wall. I have not talked to power company, but I suspect they get data from the power line, not through wireless network.
So, all you out there using a wireless setup and an Envoy to get data to computer and network and to console, do any of you have the same issues with interference, and is there and combination of id`s that seem to work best with the wireless utility mesh devices. My suspicion is I could waste a lot of time changing id`s for very little improvement, but just checking to see what others have done. I live in a standard well developed neighborhood with many neighbors using video cameras as well. I think I have helped every neighbor get their security setup so others could not get access to cameras. I know these are not the issue because they are all 2.4 band devices.
So, any ides out there would be appreciated.
As for radar. The closest Naval radar station is 40 miles and it's a small setup on a lake. The mountains around house do have AF comm stations, they are 20 miles as crow flies and are at 5000' and I am at 2000'. We do have 2 airports; one is 20 miles and other is 8 miles away. More suspicious of meters, but open to other devices to check.
