Hi folks
My soil isn't working s seen here and here, probably hasn't been for a long time but I am slowly trying to get things working but this one is proving to be annoying; any help would be appreciated, please?
Thanks.
The "official" topic for questions about the Leuven-Template =>
https://www.wxforum.net/index.php?topic=36504.0You are using a very very old version of the Leuven-Template so yes there can be problems and I personally do not have that 2014 version available anymore.
Only you can access your template settings, so these are all "guesses" of what can be the cause of not showing your soil sensors:
1. you are using WD as your data source
2. this could be the file as uploaded by WD =>
https://www.brecklandweather.com/testtags2.php?sce=view3. There are no soil-values in that file and the processing script will not have anything to show.
https://www.brecklandweather.com/ws_testtags.php?debug=yes&sce=view==> it process the soil values from line 405 onwards, if you set the soil-setting to true
if (!isset ($SITE['soilUsed']) || $SITE['soilUsed'] == false) {ob_clean(); return; }
Also, only you can check the file WD has to process to generate the testtags2.php file it uploads.
I assume the soil fields are not in that file either.
Succes, Wim
