Hi Ken,
Many thanks for getting back to me on this. After fiddling for a while, I was finally able to get some WX maps to get this done. I mis-read the instructions and was looking for "save image" in the dropdown after you do the square drawing bit.
A couple of problems that I was running into were that, besides that I was looking for the save image click in the dropdown instead of at the bottom of the page, were that if I actually drew the box around my location, the resulting map would come out to be far too high, so after many trial and errors, I ended up drawing my box about 250-300 miles to the South of my location and then it came out close enough to work with. The other thing was that after trying to draw the box once or twice, I would have to exit the map completely and start over from the main map, otherwise it would stop allowing me to draw the box. (BTW, I am using the latest Firefox on Win7. Although I did try Chrome with the same results...)
I did notice that some maps are not available, even on your site. Mode5 (entire US), Mode 4 (large section of US), and the fronts map (mode6) and flu map (mode20), so I guess these are not available.
Also, do you have to subscribe to something to get the GRLevel3 maps to download, or should I post this as a separate question? All I get is the status of my local NEXRAD station (KOKX) and the statement that "GRLevel3 radar images are not available at this time."
Many thanks for your help, and for all the hard work and time you have put into these templates. They are great!!!
Stan...
