Author Topic: Rainwise 111 rain gauge connection to VP2  (Read 1803 times)
Offline fkapp
Re: Rainwise 111 rain gauge connection to VP2
« Reply #25 on: October 25, 2021, 08:28:18 PM »
Thanks again!   [tup]
Will use the trial and error method until works as mentioned.
Any heater approaches out there?
Thanks everyone.
« Reply #26 on: October 25, 2021, 09:04:09 PM »
I feel guilty for not giving you a definitive answer so I just went out and looked. It is indeed as you said, yellow/green one side, red the other. Black not used.
« Reply #28 on: November 20, 2021, 11:04:09 AM »
New Rainwise mounted on The Davis base.
« Last Edit: November 21, 2021, 07:37:52 AM by ocala »
« Reply #29 on: November 20, 2021, 03:16:26 PM »
You're the only person I know that did it like this. Looks like stock. Very nice! Good and sturdy too. You'll like it.
Offline Dj1225
« Reply #30 on: November 20, 2021, 03:52:47 PM »
How did you get yours mounted on the Davis base? I tried and didn't seem to have the room to fit it on the base.
« Reply #31 on: November 21, 2021, 07:40:04 AM »
Had to do some mods on on the Davis base. After removing the Davis tipper assembly what's left is the two cones that the tippers spilled into. Instead of trying to grind those down I decided to use them. Had to make a few cuts in the Davis mount but eventually the new base sat right on top of those. I wanted to use the screws that attached the base to the radiation shield but I needed longer ones because it didn't sit flush. Problem is I couldn't find 8/32 x7 SS screws so I decided to use just regular deck screws to attach the the new base to the old one. Worked out good. Surprisingly it wasn't too far off from being level. A few more tweaks and it was good to go.
If you go this route mount the base  so that the light blue cap is in front. See pic above.  Reason is the back side has to be clear to attach the bolts to a 4x4. I didn't realize that and had to change things around. Also doing it this way I had to cut off one of the tabs that holds the rain bucket to the base. Reason being it sat on top of the back end of the ISS mount. So in the end the bucket is only held down by 3 screws but that will not be an issue.
« Last Edit: November 21, 2021, 07:43:11 AM by ocala »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #32 on: November 21, 2021, 10:13:54 AM »
This looks like what may be my choice once I run out of spares.
Looking at the inside it appears to me the reason it handles heavy rain better is that the buckets are simply larger. The Davis is so small that when drops are still dropping through as the bucket starts to tip, they are not registered since they belong in the next bucket but fell into the full bucket as it tipped.
The small size of the Davis tipper means those drops are a more significant part of the total and so skews the data more than the RW would.
Something else that should be checked on your Davis units is the tipper axle. Having found every used one I acquired to be bent, I suspect it happens during winter during ice build up and depending on the severity could bring tipper closer to screws and increase readings or make tipper harder to tip, lowering readings.
What does the axle look like on that RW?
Offline Dj1225
« Reply #33 on: November 21, 2021, 06:04:27 PM »
Since the drain holes for both bases don't line up, did you drill drain holes in the Davis base?
« Reply #34 on: November 21, 2021, 06:11:19 PM »
That won't be necessary, the water will always be able to drain. Remember, you can put the RW anywhere you want, it doesn't have to be on the ISS.
« Reply #35 on: November 21, 2021, 06:25:57 PM »
No. The RW drains onto the old Davis base and the water runs over the edge. Before, the Davis drained on to the top of the radiation shield and ran over their sides.
« Last Edit: November 21, 2021, 06:30:36 PM by ocala »
