Author Topic: Weatherlink connectivity after disconnect  (Read 319 times)
Offline snakey1989
« on: May 12, 2022, 07:27:18 PM »
Hey all,
I suspect I already know the answer, but I'm here for someone to prove me wrong.
The missus unplugged the USB cable from the 6510USB to the computer, about 2 weeks ago, to move the computer desk around.
Obviously, I have reconnected it and want to extract the stored data, but I'm guessing that I will have to do a cold reset to get it all connected again? Ornis there a way to get it to recognise the device again, (I see it inbdevice mngr, but weatherlink does not recognise it)
Cheers in advance,
Offline Randall Kayfes
  • Weather - Photography - Astronomy - Computer Admin
    • Arizona Kaymann
Re: Weatherlink connectivity after disconnect
« Reply #1 on: May 14, 2022, 05:22:44 PM »
Just make sure in device manager that it has not been assigned a different port number:
Device Manager>Ports (COM & LPT)>Silicon Labs CP210x to UART Bridge (COM#)
Replace # with what you actually see in Device Manager
IN WL under setup communications port make sure the com port # matches and you should be good to go.
