Weather Software => Cumulus => Topic started by: Farmtalk on June 14, 2015, 10:28:19 AM
Hola everyone, I reconnected my station back up to Cumulus, and it's running great. Unfortunately, for whatever reason, the 'Records' page is showing some really crazy values. Is there a way to clear these values within Cumulus?
for whatever reason
You've chosen a station type which has solar sensors. Choosing the wrong type of station is a good way to get invlaid data logged. Does you station actually have light and UV sensors (rather than just solar power)? Is there a way to clear these values within Cumulus?
If you have indeed chosen the wrong station type, the best way to recover, as you have apparently started again from scratch just a couple of days ago, is to start again from scratch but with the correct station type selected.
Eric
I see, yes mine just has solar power. That would probably be the issue. 8-)
Hello
I also have this type of issues. When i restart Cumulus sometimes appears that unrealistic data are registered into Cumulus.
My computer is running all the day so i don't have really the problem but one collegaue of me restart is computer every day so he have often issues on data
Thanks for your help
