Weather Software => Weather Display => Topic started by: KK7X on September 17, 2018, 06:51:36 PM
Trying to get WD to display properly. Version 10.37S81 Registered. Testtags V 1.7. Went through setup several times and also used the wizard. Showing
testtags.txt and testtags.php in Special File Conversion. What could it be.
http://rathdrumweather.us/newajax/
are you saying that the testtags.txt is not being created by WD?
Create it yourself. put it in your files and see if WD fills it in during upload.
testtags.txt is located in C:\wdisplay\webfiles but is not being updated/uploaded
Create and upload testtags.txt as testtags.php is checked in Web Files Setup #1
I downloaded the WD template files from Saratoga and added the new test tags to Version 1.7
Thinking of just starting over from scratch.
The testtags.php is being created but not uploading. Running version 10.375 so it should work.
I am guessing the solution is to do Manual setup of testtags.php upload. It should be working
without this step. Thoughts anyone?
