Weather Software > My AcuRite smartHUB Software
Acurite Access Firmware 47
WonderWX:
Data posted to atlasapi.myacurite.com - 5 minute interval (lightning detector is removed from atlas)
"POST /weatherstation/updateweatherstation?&dateutc=2018-09-28T12:59:01&id=00C03DB33F00&mt=Atlas&sensor=00000000&sensorbattery=normal&rssi=4&hubbattery=normal&baromin=29.97&uvindex=1&lightintensity=9800&measured_light_seconds=1031&strikecount=&interference=&last_strike_ts=&last_strike_distance=&humidity=86&tempf=55.2&windspeedmph=2&winddir=245&windgustmph=4&windgustdir=326&windspeedavgmph=1&heatindex=54.5&feelslike=55.6&windchill=55.2&dewptf=51.1&dailyrainin=0.00&rainin=0.00 HTTP/1.1" 404 169 "-" "Atlas/047"
Data to www.wunderground.com - 10 seconds interval
"GET /weatherstation/updateweatherstation.php?ID=PWSID&PASSWORD=PASSWORD&softwaretype=myAcuRite&dateutc=now&action=updateraw&realtime=1&rtfreq=36&action=updateraw&realtime=1&rtfreq=35&baromin=29.99&uvindex=1&humidity=82&tempf=58.1&windspeedmph=1&winddir=292&windgustmph=4&windgustdir=267&dewptf=52.6&dailyrainin=0.00&rainin=0.00 HTTP/1.1" 404 169 "-" "Atlas/047"
'&uvindex=' is not correct for wunderground, it should be '&UV='
Has anyone worked out how to use the &lightintensity=xxxx value as &solarradiation ([W/m^2])
beta firmware? smartHub_v048.bin
nincehelser:
--- Quote from: WonderWX on September 28, 2018, 09:47:52 AM ---Data posted to atlasapi.myacurite.com - 5 minute interval (lightning detector is removed from atlas)
--- End quote ---
There are several problems in the data string that have been reported. I don't know why they haven't pushed an update yet.
One outstanding issue is that wunderground wants Acurite to send data to rtupdate instead of www. That apparently had been causing issues with rain-rate calculations (don't ask me why) since wunderground's code re-write last spring. Wunderground eventually put a "temporary" fix in place, but says the host name needs to change.
WonderWX:
--- Quote ---Has anyone worked out how to use the &lightintensity=xxxx value as &solarradiation ([W/m^2])
--- End quote ---
lightintensity=LUX
using http://bccp.berkeley.edu/o/Academy/workshop_09/pdfs/InverseSquareLawPresentation.pdf
...for the SUN, there is an approximate conversion of 0.0079 W/m2 per Lux.
seamonkeys1:
--- Quote from: nincehelser on September 28, 2018, 11:18:29 AM ---
--- End quote ---
--- End quote ---
is 048 coming out soon to fix theses issues? how often does Acurite release firmware for the access device?
WonderWX:
--- Quote from: seamonkeys1 on January 19, 2019, 12:03:33 AM ---is 048 coming out soon to fix theses issues? how often does Acurite release firmware for the access device?
--- End quote ---
Hi, Most recent RC/beta is 050 as of January 11. They did not release 048 and 049. At least they are working on it!
Best approach is to combine the data from the WU upload data and the MyAcurite upload data and use a custom uploader for WU and any other site. Waiting for Acurite to make a solution which satisfies will only frustrate.
[#] Next page
