Will I lose all of my current station data for the year?
Any suggestions? Things to do? Things not to do?
The only data you will lose is your current Ambientweather.net history. Well you wont really lose it because it will still be there, it just will not be integrated with your WeatherBridge data. The way that Ambientweather.net works is that each station data is separated by MAC address of the console that does the uploading. You'll be able in your Ambientweather.net account to select either station. After one year this is a mute point anyway because there is only 1 year of history kept on this service.
My suggestion for things to do, not do:
- Make sure that you only upload to any given online service with one device for every given ID. Meaning that you likely want to continue to upload to WU with your current ID. You can either keep the existing Ambient console uploading there or you can make the GW1000 be the one or you can make the WeatherBridge be the one....but just make sure that only one uploads to any given ID. If you would like to track how several consoles upload then you can just create additional WU IDs and then have each upload to their own ID. I suggest having the GW1000 be the one to upload to WU.
- If you set up alternative duplicate WU IDs for each console then I suggest you not put them all on top of each other. Don't put them on top of your neighbor's house either. Rather you should put them in a common area near your house...maybe in the middle of some forest, or at the park accross the street...you get that idea. This way they will be easier to select on Wundermap. Take note of what distance you need to be to show up at the proper zoom level as a separate station.
- If you decide to use the WeatherBridge (Meteobridge) to upload to WU then I suggest you turn on the check mark to enable "Alternative rain rate." this will make it so that rain rate is the same method as your other consoles. As there is Instantaneous rain rate and hourly rain rate and they depict different things. Alternative rain rate refers to instantaneous rain rate which is the method that all Ambient/Ecowitt/Fine Offset clones use to upload to WU. The hourly rain rate method is how Acurite stations upload to WU. Both methods graph totally different and they really are very different.
- Remember to disable AmbientCWOP.com if you decide to have the Meteobridge upload to CWOP...which I recommend you do.
