Author Topic: Temperature way off - by 45 or so degrees!  (Read 1020 times)
Offline swthurmond
« on: October 07, 2019, 09:53:13 PM »
I have an older Accurite 5 in 1 that I took down for Hurricane Dorian. I put the batteries back in on Friday and set it back on the post outside. It says it is 114 degrees with a heat index of 158!!!  I removed the batteries, opened it up and cleaned everything. It is now sitting in the house reading 109 with a heat index of 155 for outside. Can I assume it is probably beyond repair?
Thanks in advance.
Offline nincehelser
Re: Temperature way off - by 45 or so degrees!
« Reply #1 on: October 07, 2019, 10:02:50 PM »
It sounds like a bad temp/humidity sensor.  Depending on the age of the unit, it can be replaced for about $13 without soldering.
If it's an older unit, you can likely still replace it with the $13 module, but you'll have to cut the 4 wires and solder them into the appropriate spots on the motherboard.
If it's a really old unit with 7 wires, it is toast.
Offline nincehelser
« Reply #2 on: October 07, 2019, 10:04:23 PM »
This is a long-shot, but you might try doing a hard-reset of your display.
Offline DoctorKnow
« Reply #3 on: October 08, 2019, 08:28:06 AM »
Take out batteries, move the ABC switch around, put it back on the correct original setting, and replace batteries. If this doesn't fix it, the thermo/hygro chip is bad.
Offline worachj
  • Twin Cities, Minnesota
« Reply #4 on: October 08, 2019, 08:44:45 AM »
Replacement Temperature and Humidity Sensor for Compatible 5-in-1 Sensors
https://www.acurite.com/temperature-and-humidity-sensor-replacement-for-5-in-1-weather-sensors.html
AcuRite Atlas
KMNSAINT173
Offline swthurmond
« Reply #5 on: October 08, 2019, 06:57:31 PM »
So if I remove the current sensor - which I have done - but still have the same readings on the display, is it the sensor or the display?  And I have removed the batteries and done the reset holding no down the set button and both arrows. Just checking before I order the replacement piece.
And thanks again for the help.
Offline nincehelser
« Reply #6 on: October 08, 2019, 07:19:24 PM »
Are all the other readings besides the temp on the display OK?
Offline DoctorKnow
« Reply #7 on: October 08, 2019, 07:30:08 PM »
If you did the reset on the display, that won't fix anything. You need to do the reset on the outdoor sensor...
