Weather Software > Heavy Weather by LaCrosse Technologies
HeavyWeather Review software time and date problem
mworthi245:
Hello,
I bought my first weather station a few days ago, a La Crosse WS-2308
The system seems to work fine, but the Heavyweather review software has a problem that I cannot resolve. When you create a template to graph the parameters such as wind,temp etc. the date and the time listed on the chart does not match the time and date listed on the heavyweather history file. The time and date is off by 5 hours on the graph points :?: , but is correct when you check the Heavyweather history file. The time and date is correct on the base unit. I have reloaded the software and the same problem occurs. Any help you can give a newbie would be great.
msdawg911:
I have a WS-2310 (a very similar brand), and I used to use the HW series. My guess to your problem would be that the program is using UTC time. Check in the program options for a time adjustment.
mworthi245:
Thanks for the tip about the time zone issue. I checked all the options that I could find in the pull downs. You can adjust the the format for the time display style but not the time zone, as far as I can tell.
msdawg911:
OK, sorry. Maybe someone else will know something about it.
wuhu_software:
--- Quote from: "msdawg911" ---I have a WS-2310 (a very similar brand), and I used to use the HW series. My guess to your problem would be that the program is using UTC time. Check in the program options for a time adjustment.
--- End quote ---
You are correct, it is UTC time and that is not adjustable. Why they did this I am not sure.
You can run WUHU in direct serial mode (no more Heavyweather) and have it generate a currdat.lst file with local time.
It can also write the history in Heavyweather Pro format (free program) that is more sophisticated that the Heavyweather Review.
See:
http://tech.groups.yahoo.com/group/wuhu_software_group/
[#] Next page
