Author Topic: E field Boards  (Read 5970 times)
Offline 92merc
  • BismarckWeather.net
Re: E field Boards
« Reply #50 on: May 12, 2014, 12:31:07 PM »
Is that a bulk cable, or pre-made lengths?  Just so I know what to look for.
Thanks Don.
Offline dfroula
Re: E field Boards
« Reply #51 on: May 12, 2014, 02:20:52 PM »
The cable comes in pre-made lengths, connectors attached
I recall seeing 25, 50 and 100 foot lengths at Menards and Lowes. Menards (as usual) was significantly cheaper.
Here's a shot of the packaging:
Don
WD9DMP
Offline W3DRM
    • Emmett Weather
Re: E field Boards
« Reply #52 on: May 12, 2014, 11:13:21 PM »
What are the dimensions for both of the E-field boards?
I notice in the latest manual on Pg27, Fig 26 (right-side image) the two boards appear to be connected via a F-male to F-male connector (no coax used). That is what I am going to do when my kit arrives. I am planning on using a smaller 3/4" or so PVC pipe to hold the vertical antenna wire and then using an adapter tie that to a 3/4" to ???-inch lower section of PVC that will hold the larger E-field amp board. That's why I need the dimensions of both boards.
« Last Edit: May 12, 2014, 11:20:00 PM by W3DRM »
--- RIPE Atlas Probe - 32849
