Hi all!
I'm Stefano, a new member of the forum.
I was thinking to add a weather station to my Home Assistant setup, and I found out about Ecowitt, so I can add the WH51 Soil Moisture Sensor for my wife plants
Actually I found out of Ecowitt because my wife sent me the image of this sensor
So of course I want something more... and I want to add a weather station to our home automation setup
So, getting to the subject, I live in Rome, Italy, in a 2° floor apartment in a flat of 7 floors. Unfortunately I can't install anything on the roof, because I can't run a cable from the roof to my apartment, and even if I could... it wouldn't be safe.
I was thinking to install the GW2000 gateway and then a sensor (WS90 or WS69 I don't know which is the best) on my balcony rail. The red cross is where I was thinking to install a pole, 50cm long, going outwards and then install the weather sensor on it
If I install the sensor how I perfectly drawn on the images (
) it would been exposed perfectly to South. I think that if the wind direction is North, the sensor wouldn't get the correct direction, right? Actually I'm thinking that the wind speed and direction sensor wouldn't even move right? I think I can't do anything about it correct?
But will this invalidate also the wind direction and speed readings, if the wind direction is from the other Cardinal points ? Do you see any other issues with this setup?
Thanks to all the kind replies!
Map of my apartment:
