Author Topic: new firmware version for GW1100/GW2000: V2.1.8  (Read 1846 times)
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« on: August 10, 2022, 06:17:13 AM »
Hi!
There's a new firmware version V2.1.8 available for the GW1100 & GW2000.
Use the current WSView Plus app or the web interface of the GW1100/GW2000 ("Device Setting") to update.
Changelog for V2.1.8:
  • Added password encryption for HTTP transmission
  • Support fast uploading to the server after thunder
  • Fix the bug that the RF module may not receive data
  • Fix the bug of not reconnecting the router
The new firmware is reported via WSView Plus, but the process currently stops with a timeout during the update.
I cannot install the update at the moment.
Oliver
Offline eliteweathernz
  • Weather Enthusiast/ Weather Equipment Support
Re: new firmware version for GW1100/GW2000: V2.1.8
« Reply #1 on: August 10, 2022, 06:44:42 AM »
Timing out for me also??
Offline olicat
    • FOSHKplugin
« Reply #2 on: August 10, 2022, 07:05:06 AM »
Hi!
In the meantime, I was able to update the GW2000 via WSView Plus. The GW1100 still reports a timeout when downloading the update.
Oliver
Offline Rover1822
« Reply #3 on: August 10, 2022, 07:08:54 AM »
I can report the same, GW2000 updates, GW1100 times out.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Gyvate
« Reply #4 on: August 10, 2022, 08:32:18 AM »
the changelog is just a summary of the changelogs 2.1.6 and 2.1.7  :roll:
=> as per the changelog, there is no difference between 2.1.7 and 2.1.8
maybe they uploaded the wrong changelog ...?
I will ask them
Offline kheller2
« Reply #5 on: August 10, 2022, 09:22:22 AM »
osswww.ecowitt.net seems to be having issues with the data transfer which is a reason for the timeout.
Depending on how many times I try to upgrade, sometimes it jumps to 81% (where it failed), other times it just doesn't progress at all, but mostly it just fails at the 81% mark.
« Last Edit: August 10, 2022, 09:24:16 AM by kheller2 »
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline olicat
    • FOSHKplugin
« Reply #6 on: August 10, 2022, 09:29:31 AM »
Hi!
There's one new point:
4. Fix the bug of not reconnecting the router
As far as I remember, there was a corresponding bug report here in the forum. So this could be the fix for it.
Of course, I don't understand why points 1-3 are now included again.
Summer slump?
Oliver
Offline KC5JIM
    • KC5JIM Weather
« Reply #7 on: August 10, 2022, 11:01:43 AM »
My GW2000 just updated with no problems, took about a minute. Maybe they finally fed the hamsters running the servers.
Ecowitt Wittboy| FOSHKplugin on Pi 4
Online broadstairs
« Reply #8 on: August 10, 2022, 12:22:09 PM »
I just tried my GW1100 and it failed timing out.
Stuart
Offline Rover1822
« Reply #9 on: August 10, 2022, 12:29:21 PM »
I think we have consensus it is only failing on the GW1100
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline kheller2
« Reply #10 on: August 10, 2022, 01:26:42 PM »
Dare I ask what code level you were on before the update? :)
Offline Gyvate
« Reply #11 on: August 10, 2022, 01:51:25 PM »
GW2000 updates (from 2.1.7) smoothly - the GW1100 update stalls and fails
Offline KC5JIM
    • KC5JIM Weather
« Reply #12 on: August 10, 2022, 03:18:25 PM »
I was on 2.1.7
Offline Gyvate
« Reply #13 on: August 11, 2022, 02:05:23 AM »
I will ask them
1. Oliver already mentioned
and
2. Ecowitt replied:
"V2.1.8 added a wifi reconnection mechanism: if there is no wifi connection, it will try to reconnect. Prior to this version, wifi drop out will not be retried."
Offline Gyvate
« Reply #14 on: August 11, 2022, 02:07:09 AM »
- I informed Ecowitt, but haven't received an answer yet
- still failing to download and install for the GW1100
Offline olicat
    • FOSHKplugin
« Reply #15 on: August 11, 2022, 02:14:43 AM »
Hi!
Finally they've repaired the firmware file for the GW1100 and I was able to install v2.1.8 also on my GW1100.
Regards, Oliver
Offline Gyvate
« Reply #16 on: August 11, 2022, 02:19:04 AM »
Hi!
Regards, Oliver
must have been settled just in the past minutes - now it also worked with me
« Last Edit: August 11, 2022, 02:21:18 AM by Gyvate »
Online broadstairs
« Reply #17 on: August 11, 2022, 02:21:53 AM »
I'm still getting an upgrade error right now.
Stuart
Online broadstairs
« Reply #18 on: August 11, 2022, 02:27:48 AM »
Well it worked OK from the app on my phone but failed first on my computer using the web interface.
Stuart
Offline Gyvate
« Reply #19 on: August 11, 2022, 02:32:05 AM »
Stuart
well, well - maybe upgrade the firmware for being able to upgrade the firmware .... ?  #-o
Offline Gyvate
« Reply #20 on: August 11, 2022, 04:13:22 AM »
as per ecowitt, by mistake, the download for the GW1100 took the GW2000 firmware which wouldn't then work in the end.
This shows again, as @kheller2 already reported earlier, that the two firmwares are not identical on the code level.
Ecowitt will change their internal procedure how to provide the GW1100/GW2000 upgrades in order to avoid such issues in the future.
« Reply #21 on: August 11, 2022, 04:14:33 AM »
Update worked for me.
Now upgraded to 2.1.8
Offline Jonesy
« Reply #22 on: August 11, 2022, 06:13:34 AM »
I just upgraded to 2.1.8 from 2.1.7 for the GW2000 via webpage interface without issue. I noticed it took 0.2mm away from daily piezo rainfall from 6.4mm to 6.2mm after the update :?:
Offline BaseLine
« Reply #23 on: August 11, 2022, 06:22:25 AM »
... Prior to this version, wifi drop out will not be retried."
LOL. Imagine forgetting to add this functionality from day one. LOL. A Wifi device that has no idea how to reconnect.  =D>
Sun cooked nothingburger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline Jonesy
« Reply #24 on: August 11, 2022, 06:37:11 AM »
Previously I'd noticed that Ecowitt devices required WiFi routers have setting such that they broadcast their SSID to work consistently. If the WiFi router was set to hidden/not broadcast SSID then the Ecowitt device would not be able to reconnect if there was a reset due to power failure or WiFi router reset.
