Author Topic: Where are the scripts?  (Read 88924 times)
Offline W3DRM
    • Emmett Weather
Re: Where are the scripts?
« Reply #25 on: January 26, 2011, 12:16:20 AM »
Ken,
I was looking through your list of scripts and found the following link to be inactive. Clicking on the link shows the domain to be for sale...
Mike of Long Beach, WA (http://www.carmosaic.com/weather/scripts.php) has a new Scripts section with:
    * PHP Multifunction Image Handler
    * PHP Webcam Text Overlay
    * PHP WeatherUnderground Webcam Uploader
    * PHP List Generator
    * Wind-rose Graphics (for ajax-dashboard/ajax-sidebar or AJAX scripts ajaxWDwx.js or ajaxVWSwxf.js)
    * Style Sheet generator/modifier for Carterlake/AJAX/PHP script template set
    * Theme Selector plugin for Carterlake/AJAX/PHP script template set
Found another one:
 Jim at Esperanza Weather Center ,Lexington Park, Maryland (http://espwxctr.com/wxscripts.shtml)
  * UPPER AIR SOUNDING AND RAPID UPDATE CYCLE (RUC2) SCRIPTS
     This script retrieves and diplays the latest Upper Air Sounding report and RUC2 runs. This script can be configured for
     various station IDs.
  * TROPICAL HIGH-DENSITY OBSERVATION REPORT
     This script displays the latest HIGH DENSITY OBSERVATION reports. These reports are derived from US Air Force
     reconnaissance flights into tropical storms and hurricanes.
  * TROPICAL VORTEX REPORT
     This script displays the latest VORTEX report from NOAA reconaisance flights into the center of tropical systems.
« Last Edit: January 26, 2011, 12:23:22 AM by W3DRM »
--- RIPE Atlas Probe - 32849
« Reply #26 on: January 26, 2011, 01:51:11 AM »
Got 'em both corrected with new URLS
Mike at http://www.642weather.com/weather/scripts.php
Jim  at http://www.somdweather.com/wxscripts.shtml
Thanks for the heads-up, Don!
Best regards,
Ken
Offline Tornado Tim
    • Matangi Weather
« Reply #27 on: April 29, 2011, 09:38:55 PM »
Hey Ken you can add my script for L2k display :)
It can work without the templates or with the templates.
It displays Lightning 2000's Data and Lightning Maps and  Graphs it.
Lists the current storms, severity, CG % and IC% and other data.
Lightning Data is AJAX driven so it automatically updates as well as the Lightning Map(s).
URL: http://wx-matangi.dyndns.org/Weather/wxl2kdisplay.php
Live Example: http://wx-matangi.dyndns.org/weather/wxl2k.php
« Last Edit: April 29, 2011, 09:42:34 PM by Tornado Tim »
http://NZAPStrike.net - Oceania Blitzortung Lightning Network
http://Matangiweather.org - Matangi Weather Station
Davis VP2 with Daytime FARS with Solar
Offline gmu
« Reply #28 on: February 24, 2013, 03:59:03 PM »
has anyone tried Bindows gauges to report weather data?  here's an example that reads clientraw.txt.
Offline Murry Conarroe
    • Wildwood Weather
« Reply #29 on: February 24, 2013, 04:41:46 PM »
Scripts for additional addon pages for Ken's template set are available at:
http://weather.wildwoodnaturist.com/downloads.php for Weather Display users and
http://weather.wildwoodnaturist.com/downloadsCVW.php for Cumulus, VWS, and Weatherlink users.
The scripts will produce reports showing Daily Records and Detail/Summary Reports based on the NOAA reports the user has uploaded to their website.
JPGraphs can also be created for the temperature, rain, and wind data in the NOAA reports.
Murry
Offline Piero
  • Valenza - Italy
    • Luna Weather Station - Valenza
« Reply #30 on: March 06, 2013, 05:19:24 PM »
I tried the script by Ken "Recent nearby earthquakes (from USGS, NRC, BGS) PHP", really nice, well built and useful.
However, the database from which it takes the data does not have much information about earthquakes Italian, so I can not use it.
The Italian site more informed about earthquakes is this: http://iside.rm.ingv.it/iside/standard/index.jsp?lang=en.
The webmaster says their database is public, and citing the source, you can extract the data.
It would be possible to adapt the script of Ken to make him take the data from this site?
Thanks and best regards to all
Piero
Davis ISS and Weather Envoy
Weatherlink IP
Virtual Weather Station
Cumulus
Weatherlink
www.lunavalenza.altervista.org
« Reply #31 on: March 18, 2013, 01:11:43 PM »
I am trying to use the Murry Conarroe 'NOAA Reports' scripts but am at a blank.  I have edited the wxnoaarecords.php and wxreport-settings.php, and uploaded all files to the root.  I was not able to find which file to run so added some in  'NOAA Reports' but get only a blank www.komokaweather.ca  I have obviously missed a key part.  But what?
    • Wildwood Weather
« Reply #32 on: March 18, 2013, 02:23:41 PM »
There are threads specific to the Daily Records script at http://www.wxforum.net/index.php?topic=14081.msg137471#msg137471
and the Detail/Summary scripts at http://www.wxforum.net/index.php?topic=14077.msg137449#msg137449
I am more likely to see postings about those scripts there.
Try changing the path to the NOAA reports in the settings section of the wxnoaarecords.php
from
$path_dailynoaa = "./weather/reports/";             # path to NOAA reports
to
$path_dailynoaa = "weather/reports/";             # path to NOAA reports
Murry
« Reply #33 on: March 18, 2013, 04:06:00 PM »
Thanks Murry for getting back.  I now have changed to "weather/...." and also tried as ".weather/...." and "/weather/...." but no success.  Just to make sure I have understood correctly, that path would be for the NOAA files that are in my the Cumulus www.komokaweather.com/weather/reports/ folder in NOAAMO1212.txt and NOAAYR2012.txt format?
The wxnoaaclimatereports.php are in www.komokaweather.com root
I had edited wxnoaarecords-include.php line 13 from $wxsoftware = 'WD' to 'CU' but that did not make a difference.
Any other suggestions?
Thanks for your help,
EDIT
p.s. I will use the mentioned specific threads in future (should have done that for this reply - sorry)
    • Wildwood Weather
« Reply #34 on: March 18, 2013, 06:03:26 PM »
EDIT
Paul,
I have sent you a PM.
Murry
Offline wvdkuil
  • Wim van der kuil
« Reply #35 on: April 28, 2013, 08:21:08 AM »
An alternative 3in1 script.
An alternative WXSIM script is available for stand-alone use, for use in an iframe, or for use with the Saratoga template. This script was developed for the Leuven template set. The past three months it has been tested on a dozen websites in Europe and now available for download.
Demo:
Compact version: http://www.weerstation-leuven.be/wsWxsimSA/startSmall.php?lang=en
Extended version: http://www.weerstation-leuven.be/wsWxsimSA/startDemo.php?lang=en
Saratoga template: http://wiri.be/saratoga/wxleuven.php?p=forecastp
Leuven template: http://www.weerstation-wilsele.be/index.php?p=wsWxsimPrintFull&lang=nl
EDIT: removed outdated link http://www.weerstation-wilsele.be/index.php?p=12&lang=en
The above links use exactly the same scripts. One can set the different output parts, language, units of measurement and so on by a settings file.
To see the demo in a different language you can add the parameter ?lang=nl fr de or en to the link
Language support files are included in the download for: english dutch french and german.
The language files have the same structure as the Saratoga ones, so more languages can be easily added.
Download site: http://www.weerstation-leuven.be/
Wim van der Kuil
« Last Edit: June 26, 2016, 12:25:05 PM by wvdkuil »
Offline dnavarrojr
    • Weather Center
« Reply #36 on: November 03, 2013, 05:43:44 PM »
PHP script to generate a U.S. national temperature map:
http://www.wxforum.net/index.php?topic=20638.0
Dave Navarro, Jr. - The Weather Center
https://weathercenter.us
Offline imetcan
« Reply #37 on: January 29, 2015, 05:55:36 AM »
Wim van der Kuil
Hi Wim
I write with the purpose to recognize you the great great great work you did with this script.  =D> I have just installed your script and I must recognize that works very nice. My next step is to translate the language into Spanish, but this is not gonna be a problem ... I think  \:D/
best regards
« Last Edit: April 05, 2017, 05:27:53 AM by imetcan »
Offline vinesweather
    • The Vines Weather
« Reply #38 on: February 10, 2015, 01:55:22 PM »
Does anyone know why we can't download the Trac Report script from Carter Lake?
Offline jmcmurry
  • Jim McMurry
  • Davis Vantage Pro 2 Plus Wireless.
    • Juneau County Weather
« Reply #39 on: February 11, 2015, 05:17:08 AM »
Like many of us, he had to change servers when e-rice went down.  I suspect that script may have not made the move?
- Jim
Forum Search and Google Can be Your Best Friends
    • The Vines Weather
« Reply #40 on: February 11, 2015, 05:20:06 AM »
Ah, thanks Jim.
    • The Vines Weather
« Reply #41 on: March 29, 2015, 03:14:41 AM »
Anybody have a copy they could send me please?
« Reply #42 on: March 29, 2015, 11:12:47 AM »
Here's what I think you wanted (from 2006)
<?php
// The TRACreportshort takes Nexstorm's full TRACreport and shortens it to a more
// managable size for displaying.
// It chops up the vital storm cell info, places it in arrays, and redisplays it as we wish
// Set some default values
$measure "mi"// km, nm, or mi depending on your Nexstorm measurements
$tracwarnmeasure 50// number of measure to trigger a storm cell warning
// Load the TRACreport and remove carriage returns, change the word 'no change' to 'steady'
$trac implode(''file('TRACReport.txt'));
$tracnopara preg_replace'|\n|''='$trac );
$tracnopara preg_replace'|No change|''Steady'$tracnopara );
// Intialize values
$tracreport "";
$tnumber 0;
$alertflag 0;
$tracwarning "";
// If there aren't any thunderstorms, then say it
if (preg_match("/No thunderstorms detected/i"$trac)) {
$tracreport "No thunderstorms detected"; }
else {
// If there are thunderstorms, process them, putting them into various arrays
// $tnumber[x] is for number of thunderstorms
preg_match("/Tracking (.*) thunderstorms/Uis"$tracnopara$tnumber);
// $tid[x] is the ID number of the storm
preg_match_all("/Thunderstorm ID (.*) detected/Uis"$tracnopara$temp);
$tid $temp[1];
// $tdtime[x] is the time detected
preg_match_all("/detected (.*)=/Uis"$tracnopara$temp);
$tdtime $temp[1];
// $tdirection[x] is the direction of the storm
preg_match_all("/Storm location bearing (.*) dgr/Uis"$tracnopara$temp);
$tdirection $temp[1];
// $tdistance[x] is the distance in $measure amounts
preg_match_all("/distance (.*) $measure/Uis"$tracnopara$temp);
$tdistance $temp[1];
//$tintensity[x] is the intensity of the storm
preg_match_all("/Intensity class (.*)=/Uis"$tracnopara$temp);
$tintensity $temp[1];
//$ttrend[x] is the trend of the storm
preg_match_all("/Intensity trend (.*)=/Uis"$tracnopara$temp);
$ttrend $temp[1];
// Set working for the header based on number of thunderstorms
if ($tnumber[1] == 1) {
$tracreport "Tracking " $tnumber[1] . " storm cell<br/>";
} elseif ($tnumber[1] > 1) {
$tracreport "Tracking " $tnumber[1] . " storm cells<br/>";
} else {
// Sometimes the TRACreport is empty so we need to say that
$tracreport "No data currently available<br/>";
// Process the arrays
for($k=0;$k<$tnumber[1];$k++) {
// Sets the alert flag to 1 meaning that there is a storm within a given distance
// This can be used to display an alert to visitors
if ($tdistance[$k] <= $tracwarnmeasure) { $alertflag 1;}
// This builds each line of text for each thunderstorm
$tracreport $tracreport "Cell ID " $tid[$k] . " detected at " $tdtime[$k] . " from " $tdirection[$k] . "&deg; at a distance of " $tdistance[$k] . " miles. Storm is " strtolower($tintensity[$k]) . " and " .  trim(strtolower($ttrend[$k])) . ".<br/>";
$tracreport $tracreport '<br/>';
if (
$alertflag == 1) {
// You can change the HTML in this warning to anything you want.
// I display it on my main webpage with a link to the lightning page
$tracwarning '<br />LIGHTNING ALERT</b> ... We have detected a nearby storm cell ... <br />';
echo
$tracreport;
echo
$tracwarning;
    • The Vines Weather
« Reply #43 on: March 31, 2015, 05:17:00 AM »
More the trac graphic. I can't get my original to work
Offline garlandclan
  • In the ACTUAL Northern California
    • Garland Clan Weather
« Reply #44 on: November 15, 2015, 06:59:52 PM »
No sure what I'm missing, but I can't seem to find the wxfishing, or wxhiloavg scripts.  I assume they're in a package I don't yet have, but can't find them with 'the google' searches....
Sean Garland
Offline AWL
    • Ardmore Weather Live
« Reply #45 on: November 15, 2015, 07:11:57 PM »
Sean Garland
wxhiloavg here: Weather Scripts and Graphics by Burnsville Weather
-Doug
Offline MeteoGerena
    • MeteoGerena
« Reply #46 on: November 20, 2015, 08:03:43 AM »
Where I can disburden the script wxastro5.php since one sees in this link http: // www.meteocarmignano.it/wxastro5.php
Offline virusdunil
    • Station Meteo Hebertville
« Reply #47 on: December 18, 2015, 07:37:30 PM »
Hi...Can someone point me to where to dload the MOON icons set please...the ones with these names...
ajax-images/moon/w/NH-moon07.gif
Thanks ;)
Cabled Vantage pro2 + Solar / Stevensen screen
Weather Display latest version + Boltek PCI-NexStorm-StormVue NGX / NSDisplay
http://www.meteolacstjean.com/weather28/index.php
Meteotemplate : http://www.meteolacstjean.com/hebert/index.php
Offline Maumelle Weather
    • Maumelle Weather
« Reply #48 on: December 18, 2015, 07:52:52 PM »
Attached are the moon icons you are looking for.
GR2AE, GR3, Cumulus
Offline virusdunil
« Reply #49 on: December 18, 2015, 07:54:56 PM »
That was fast...thanks  :lol:
