I have a Davis Vantage PRO2 Model 6153 weather station that I purchased new in December 2006.
The console unit has a Mfg Code of A61005D80D
I need to replace the temp/humidity sensor that slides down into an opening INSIDE the radiation shield. Once installed, the sensor sits just below the fan unit. I have located a sensor, but I'm not sure it will mount properly ........... and possibly may not function with my unit!
The part number is: 7346.070 (SHT31)
The best I can tell from the photo of the new sensor is that it appears to be somewhat like the one I now have. From the photo, it's difficult to tell if the board dimensions are the same as my current sensor and therefore if it will be able to slide down into the slots of the radiation shield. It also has a tab for mounting the sensor with a screw. Mine does not have the tab for mounting and I'm not sure if this will pose an issue when I try to slide it into the radiation shield slots?
Can anyone help with this?
Thanks so very much!!
