Author Topic: Wind direction glitches with Vantage Pro 2  (Read 7840 times)
Offline ShadySquirrel
Re: Wind direction glitches with Vantage Pro 2
« Reply #25 on: March 29, 2025, 09:08:34 PM »
Hi, I have a VP2 from 2018, and after several months on wind direction showing N or exactly 360° around 20-50% of the time, I bought a new anemometer in 2022.
Now, in March 2025, I noticed that the 360°/N is starting to appear since around 23 March, and getting worse by the day, as in today March 29 it is around 20% N, and no, there is good wind speed and visibly checking it, it is pointing East.
So... Are these things like cartridges, should be replaced every 3-5 years? I also had to change hum/temp sensor because humidity was around 20% below expected as in other analog readings.  :-(
Offline Mattk
« Reply #26 on: March 29, 2025, 09:22:45 PM »
VP2 wind cartridge is only wind speed not wind direction.
If you have wind and indicating North (0°) when it's not northerly then it's one of two things, in the connector and/or cable somewhere or a failed anemometer. It doesn't surprise me a current 3 year old anemometer fails like this. The potentiometer is not really a replacement item like the wind speed cartridge.
« Reply #27 on: March 29, 2025, 09:50:26 PM »
Thanks for the reply Mattk!
Oh sorry, for the inappropriate terminology, I was thinking in 'cartridge' as in razor blade or printer ink, things that need to be replaced constantly, and I missed the fact that there is an actual wind cartridge that could be confusing when talking about this issue.
But then, are 3 years the current lifespan of the wind direction potentiometer? Does everybody else changes theirs at such intervals?
Offline johnd
« Reply #28 on: March 30, 2025, 07:08:01 AM »
In general - there are always occasional exceptions - the 6410 direction pots last for many years. Commonest cause of wrongly indicating North is an intermittent short to ground somewhere in the cabling or connector, eg could be a frayed cable, an intermediate cable joint that is not properly waterproofed or moisture getting into the wind connection. But a fault developing in the wind input circuitry of the SIM board can also happen sometimes.
But I don't disagree that the anemometer, along with other VP2 sensor elements, is best regarded as a consumable item, albeit with a decent working life, say 5 years. That said, many anemometers can last much longer and still function well. My own home station has an anemometer that now must be 10-12 years old and still seems to be functioning fine.
Cambridge UK
Offline rodrigocatarino
« Reply #29 on: March 30, 2025, 12:03:29 PM »
Hi all,
In my case i think it's the ISS, as i bought a complete new wind speed/direction sensor, and conected directly to the ISS and was always pointing north.
Is my theory correct?
Regards,
Rodrigo
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #30 on: March 30, 2025, 01:41:12 PM »
Not a bent/dirty pin on socket where sensor plugs in?
« Reply #31 on: March 30, 2025, 02:50:49 PM »
Checked that as well, also applied contact cleaner although the pins were shinny.
Offline Mattk
« Reply #32 on: March 30, 2025, 04:45:20 PM »
Yes that's possible but typically not normal
And just to confirm you have no extension cable or another long shot is not plugged to the [Wind] input?
« Reply #33 on: March 31, 2025, 04:45:52 AM »
I have an extension, and was working for more that 10 years.
But the test I've made was connecting the sensor directly to the ISS, so no extensions nor other connections in the middle.
Regards,
Rodrigo
« Reply #34 on: March 31, 2025, 07:55:16 AM »
Another thing I've been noticing today, sometimes the wind speed reading, shows two dashes "--" and the wind direction also disapears.
Just like when i disconnect the sensor from the ISS.
It could be when there is no wind, but today the average wind speed is around 20kph.
Offline Mattk
« Reply #35 on: March 31, 2025, 04:40:17 PM »
With no wind, there will obviously be no wind speed, hence also unknown wind direction, nil wind speed will dash out the wind direction and is not related to the average wind speed over time.
« Reply #36 on: April 01, 2025, 09:31:05 AM »
What i meant was that there were wind and the reading was if no sensor was connected to the ISS.
« Reply #37 on: April 10, 2025, 11:34:05 AM »
Just an update on the wind direction issue.
I ordered a new ISS board, and now i see the wind direction, so it was a problem with the ISS itself.
Regards,
Rodrigo
