Author Topic: Station Graphs not loading  (Read 533 times)
Offline SierraFoothills
    • Rail Road Flat Weather
« on: August 03, 2021, 10:12:50 PM »
Is there an obvious reason wxgraphs.php is not loading?
https://www.railroadflat.org/weather/wxgraphs.php
https://www.railroadflat.org/weather/check-fetch-times.php?show=versions
I recently updated the site and it was working.
Mike
Re: Station Graphs not loading
« Reply #1 on: August 04, 2021, 08:18:43 PM »
Looking at https://www.railroadflat.org/weather/check-fetch-times.php?show=info shows:
Settings-weather.php $SITE['graphImageDir']='./davcon' exists; but does not have contents (curr24hourgraph.gif tested). Set WD software to upload contents for proper template operation.
Looking at Settings-weather.php shows
$SITE['graphImageDir']  = './davcon';  // directory location for graph images with trailing / and that needs a trailing / to be
$SITE['graphImageDir']  = './davcon/';  // directory location for graph images with trailing /  (and that assumes the WD graphs are uploaded to the ./davcon/ directory)
However, I see that https://www.railroadflat.org/weather/curr24hourgraph.gif does exist, so change Settings-weather.php to
$SITE['graphImageDir']  = './';  // directory location for graph images with trailing / and the history images should work.
« Last Edit: August 04, 2021, 08:21:11 PM by saratogaWX »
« Reply #2 on: August 04, 2021, 10:19:42 PM »
That did it. Thank you Ken.
Mike
