Author Topic: error in submit.php, Wflash  (Read 7954 times)
Offline Axelvold
« on: April 03, 2009, 01:35:42 PM »
I get the following error i my server error file,
[Fri Apr 03 18:44:13 2009] [error] PHP Notice:  Undefined index:  F in H:\\htdocs\\Flash\\scripts\\submit.php on line 9
This is what submit.php looks like, line 9 in bold.
<?php
header("Cache-Control: no-cache, must-revalidate");
header("Pragma: no-cache");
header("Expires: Mon,26 JUL 1997 05:00:00 GMT");
// Please change USERID below to the User ID supplied
// Do NOT alter anything else in this file
if ($_GET["I"]=="userid" ){
  if ($_GET["F"] != ""){
      $fp=fopen("../Data/wflash.txt", "w");
      $TempStr=$_GET["F"];
      $TempStr2=str_replace(" ","+",$TempStr);
      fwrite($fp, "F=".$TempStr2);
   }else{
      $fp=fopen("../Data/wflash2.txt", "w");
      $TempStr=$_GET["S"];
      fwrite($fp, "S=".$TempStr2);
   fclose($fp);
what is wrong with it?
« Last Edit: March 09, 2010, 05:00:20 PM by Axelvold »
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline jay_hoehn
    • Jay's Woodcrafts
Re: error in submit.php, Wflash
« Reply #1 on: April 03, 2009, 05:34:36 PM »
Lars,
I compared your submit.php to mine and they are identical.  Your page seems to work on my end.  What seems to be the issue?
Jay
VVP
Weather Display
Offline Axelvold
« Reply #2 on: April 03, 2009, 05:40:41 PM »
Hi Jay
The page works, but i get an error in the web server log.
[Fri Apr 03 18:44:13 2009] [error] [client 83.209.47.5] PHP Notice:  Undefined index:  F in H:\\htdocs\\Flash\\scripts\\submit.php on line 9
i did try to change F to C but i did not make any diffrent.
Lars Magnusson
Axelvold / Sweden
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #3 on: April 03, 2009, 05:49:13 PM »
Lars,
Sorry, I can't help with that.
Jay
VVP
Weather Display
Offline Meteorologica
« Reply #4 on: April 04, 2009, 03:12:00 AM »
First I must once again emphasize that this is NOT the place to get support for WeatherFlash, you should contact us directly if you require assistance with these sort of problems! http://www.meteorologica.co.uk/contact.asp
However, I will tell you that there is nothing wrong with your script, it is designed to be the way it is. There is no error, the F variable doesn't always exist in the data string. The F does not represent temperature!
Offline Axelvold
« Reply #5 on: April 04, 2009, 04:42:13 AM »
if there now is nothing wrong with the script, still remains the question why is the error in the server log?
Lars Magnusson
Axelvold / Sweden
« Reply #6 on: April 04, 2009, 05:08:36 PM »
It is not an error it is simply telling you that the variable F is not in the data stream. That is normal, the variables that get sent to the script do change and they are not all present all of the time!
Offline Axelvold
« Reply #7 on: April 04, 2009, 05:54:15 PM »
ok, thanks for the information
Lars Magnusson
Axelvold / Sweden
« Reply #8 on: April 06, 2009, 06:24:59 PM »
And...  you can get rid of the log entry for Notice errors by changing your php.ini to have
error_reporting = E_ALL & ~E_NOTICE
You get the error with 'F' mentioned because the F= is only used to update the wflash2.txt record.
It's also possible to skip the error by adding an isset() to test for the existence of the argument first:
<?php
if (isset($_GET["I"]) && $_GET["I"]=="userid" ){
   if (isset($_GET["F"]) && $_GET["F"] != ""){
   }else{
   fclose($fp);
then the script won't log a PHP error even if the arguments are missing and error_reporting = E_ALL
Best regards,
Ken
