Author Topic: Changing battery in RainWise MK-III Weather Station  (Read 1887 times)
Offline mvignola29
    • KCTSEYMO7
« on: February 07, 2020, 11:21:50 AM »
Looking for the process to replace the battery in the Weather Station, I assume you must remove some panels to access the battery which I assume is somehow connected to the system.
Any info is appreciated
Michael
Offline zeppline
    • Las Vegas Weather Guy
Re: Changing battery in RainWise MK-III Weather Station
« Reply #1 on: February 07, 2020, 02:05:38 PM »
Turn ISS off, switch on bottom, remove 4 screw from panel that hold solar panel, unplug solar panel from circuit board and set aside. Slide battery out part way unplug battery and remove. Battery is a 6 volt wet cell. reverse to install new battery.
Offline mvignola29
    • KCTSEYMO7
« Reply #2 on: February 07, 2020, 02:29:01 PM »
Thanks for the info. Is the 6 volt battery a standard size, I am not familiar with that size battery. I assume it size is critical to fit inside the panel case.
Thanks again for the info
Offline zeppline
« Reply #3 on: February 07, 2020, 06:44:31 PM »
Duracell  SLA6-5F  Batteries + Bulbs   $21.99
