Author Topic: Home Indoor Monitoring Station with five or more temp/humid/presurrer\ sensors  (Read 1503 times)
Offline droople
Hi there,
I'm looking for an indoor monitoring station that can connect to five or more temp/humidity/pressure sensors.
Ambient Weather WS-2801A only support three sensors :(.
Any suggestions will be appreciated.
Sorry for the misunderstood. I want a console with a pressure sensor inside, meanwhile, supports 5+ temp/humid sensors.
« Last Edit: January 31, 2023, 08:33:29 AM by droople »
Offline davidefa
Ambient has also a ws-3000 ( console + 3 T/H sensors ): https://ambientweather.com/amws3000x3.html
It can be expanded up to 8 multichannel T/H sensor ( available in different forms, for different uses ), it has sd data logging and can be expanded to support other sensors too ( see this post )
The ambient version does not have wifi connectivity ( but you can add an additional gateway ).
The ecowitt version has wifi connectivity and can send your data to online services ( so you can view your data from 'everywhere' ), this is the console only: https://www.ecowitt.com/shop/goodsDetail/174#
Offline mcrossley
    • Wilmslow Astro
Five pressure sensors? I think you will be lucky. Out of interest why would you need that many?
Offline droople
Offline droople
Thank you for the suggestions, I checked the link and found this note, I guess I need to find a HP3501?
1: HP3501/3500 looks like the Ambient WS-3000 console but is totally different. The Ambient WS-3000 is running different firmware and only works with Temp/hum sensors and is not intended to be a complete weather station. Needs firmware > 1.6.2 for extra sensors.
Offline vinceskahan
    • home site
A ecowitt gw1000 I think has what you're looking for for indoor T+H+P.  It supports up to 8 indoor T+H sensors, one outdoor one, soil sensor, etc.
WeeWX sites:
  Davis VP2+DFARS to a pi4
  EcoWitt GW1000, WH32 outdoor T+H, multiple WH31 indoor T+H, WH51 soilMoisture, WH34 soilTemp (pi4)
  Davis AirLink (inside)
  PurpleAir (outside)
Home site:        https://www.skahan.net/
Wunderground: KWAFEDER15
PWS:                KWFEDER15
CWOP:              CW6881
Offline droople
Thank you for the suggestion. But I prefer something with a console, everyone can see it without going to check on a computer.
Offline Gyvate
for display consoles from Ecowitt (and clone brands) and extra temperature/humidity sensors (up to 8 per console) you have basically three choices:
- HP25x0 consoles
- HP350x console (which is pretty small)
- WS19x0 consoles which only show a selection of sensors on the display - all extra temp/hum sensors though
for an overview see https://www.wxforum.net/index.php?topic=40730.0
the proposed displayless GW1100 (or GW2000) can still be useful if you can repurpose an old (or new) Android tablet together with the Personal Weather Tablet app.
