Author Topic: new firmware version for GW2000: V3.1.2  (Read 843 times)
Online olicat
    • FOSHKplugin
« on: March 14, 2024, 01:40:33 AM »
Hi!
There's a new firmware version V3.1.2 available for the GW2000.
Use the current WSView Plus app or the web interface (WebUI) of the GW2000 ("Device Setting") to update.
Changelog for V3.1.2:
  • Fix the memory leaks and some known crashes
  • T&HP sensor can replace indoor temperature, humidity, pressure data
  • Fixed a bug when wifi is turned off
Oliver
Online broadstairs
Re: new firmware version for GW2000: V3.1.2
« Reply #1 on: March 14, 2024, 03:05:19 AM »
Just updated my GW2000, all OK so far.
Stuart
Offline jbroome
« Reply #2 on: March 14, 2024, 03:38:06 AM »
The bin file can be fetched directly for offline updates at:
https://osswww.ecowitt.net/ota/20240312/d0230943cdf23c9469244c49e32bc0e1.bin
Collector of Ecowitt and related gizmos:
GW1000 x3 (both 915 MHz and 433 MHz)
GW1100 x2 (both 915 MHz and 433 MHz)
GW1200 (both 915 MHz and 433 MHz)
GW2000 (915 MHz)
WH31
WH31P
WH32E
WH32B
WH34BS
WH34BL
WN35
WH40
WH41
WH45
WH46
WH51
WH55
WH57
WH65B
WH68
WS90BN
(and probably more that I've forgotten)
Offline Platokidd
  • top side land of Lincoln
« Reply #3 on: March 14, 2024, 04:29:36 AM »
Hi!
Oliver
 The T/H/P was addressed in prior firmware allowing the use of wh32 indoor sensor. Or am I missing something here?
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Online olicat
    • FOSHKplugin
« Reply #4 on: March 14, 2024, 04:53:54 AM »
Hi!
Unfortunately, it's as usual - the changelog is a bit unkind. The option to override the internal T/H sensor was already available with v3.1.1 - but this was not mentioned in the changelog.
I (still) hope Ecowitt will be a bit more careful with the changelogs in the future ...
Oliver
Offline Gyvate
« Reply #5 on: March 14, 2024, 05:36:54 AM »
is that so ?
from my not yet updated GW2000
Current version:V3.1.1
- Fixed bug where some devices could not upload ecowitt.
- Fix the memory leaks and some known crashes.
- T&HP sensor can replace indoor temperature, humidity, pressure data.
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
weather landing page: http://meshka.eu
WIKI http://meshka.eu/Ecowitt/dokuwiki
Online olicat
    • FOSHKplugin
« Reply #6 on: March 14, 2024, 06:08:41 AM »
Hi!
is that so ?
Yes, the changelog was was subsequently (and only after complaint) changed.
My Firmware announcement for v3.1.1 still contains the original changelog at release.
Oliver
Offline Gyvate
« Reply #7 on: March 14, 2024, 06:40:08 AM »
Hi!
is that so ?
Oliver
[tup]
Online olicat
    • FOSHKplugin
« Reply #8 on: March 14, 2024, 07:35:29 PM »
Hi!
With firmware v3.1.2 I now have significantly more heap memory. Before the reboot initiated by the update, the heap value was 106KB - now it is 143KB.
Oliver
Online broadstairs
« Reply #9 on: March 15, 2024, 05:37:56 AM »
Mine has gone up to 150512!
Stuart
Offline Patt21
« Reply #10 on: March 28, 2024, 08:09:19 AM »
Hello, after the latest update of WSview Plus, the WH32 THP sensor (located on the ground floor) is displayed instead of the THP of the GW1101 (located on the first floor); before the wh32THP was only displayed on the HP2550 console (ground floor), and the THP GW1101 was displayed on the app. How do I find the THP of gw1101 on the app? sorry because translated by GG. THX
wh40/wh41/wh45/wn32p/wh31(3/wh51(3)/wh35/wn30(4)/wn34s/ws68/hp10/hp2550.
WH32ep barani shield (8m)
wh31ep 7714 davis (2m)
wh57 +shelter
wn30 (soil T° -50cm)
wn 30 (soil T° -10cm)
ws68 (8 m)
wh31 (+10cm)
wh31 (unshielded 1m80)
https://app.weathercloud.net/d0885729038#profile
https://www.awekas.at/fr/instrument.php?id=23272
https://smartmixin.io/app/stations/42866
Offline Gyvate
« Reply #11 on: March 28, 2024, 08:49:38 AM »
if you want to show the T&HP sensor inbuilt in the GW1100, you have to disable the TH&P sensor in the WSV+ app for your GW1100. Then it will use its inbuilt sensors.
But it was not the update of WSV+, it was the update made with the help of WSV+. The upgrade was the firmware upgrade of the GW1100 to 2.3.1 which introduced the choice of T&HP sensors.
The translation is ok, even though www.deepl.com will give you better translations than Google translate.
« Last Edit: March 28, 2024, 08:53:21 AM by Gyvate »
Offline yeahme49
« Reply #12 on: April 20, 2024, 10:31:01 AM »
How can I upload my GW2000 offline with this file?
Offline Gyvate
« Reply #13 on: April 20, 2024, 04:07:22 PM »
It's not a simple but a more complex procedure where you have to create a fake website (sort of DNS spoofing) to sell a local file location as the ecowitt.com/ecowitt.net download location to the GW2000.
We are working on describing such a procedure for all the different devices and purposes (upgrade/downgrade) which will take some time. Once ready we will publish it in our WiKi.
Offline kheller2
« Reply #14 on: April 20, 2024, 04:19:49 PM »
Wow.. this is starting to sound like what was done for ReplayTV (SonicBlue/Panasonic) PVRs in the 2000s where the entire site was proxied so that channel guide data, show sharing, etc continued to work after shutdown.
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline jbroome
« Reply #15 on: April 24, 2024, 04:55:10 AM »
At the moment, we believe there are a couple of ways to do it. The fake webserver (redirect/proxy/mitm) is one possible solution that we are investigating.  Another is to simply run a standalone program that uses the GW1000 "telnet" protocol to feed the desired firmware to the device. These are very different methods, and involve differing skills to implement. So we are working on both approaches.  (The "we" to which I refer includes me and several others who may remain anonymous until we are ready to publish tested procedures.)
   ---Jonathan
GW2000 (915 MHz)
WH31
WH31P
WH32E
WH32B
WH34BS
WH34BL
WN35
WH40
WH41
WH45
WH46
WH51
WH55
WH57
WH65B
WH68
WS90BN
